Axle to Crown Questions for Fork Swap- Mtbr.com
Results 1 to 3 of 3
    Mar 2006
    Hello all. Apologies if this has been asked before. I am a total noob when it comes to a lot of the geometry and specs.
    I have been looking for a new fork for my bike. The bike is a Motobecane, size 21. I'll link to the bike and the geometry below if anyone is interested. I am not huge fan of the fork, mostly due to its weight and squishiness (Rock Shox XC30, 100mm travel coil fork). I have been looking into a rigid carbon fork. My main question is regarding the size of the fork.
    I was emailing with bikeman to see if a 465mm axle to crown would be large enough to replace my current fork. Specs on my current fork are a little hard to find (maybe because it is an OEM model?).To my surprise, my axle to crown measurement came back at about 530mm.
    Isn't this pretty long for a 100mm travel fork? I think I bought this bike at exactly the wrong time as far as tech goes. It has a straight headtube and QR axles. Are there any recommendations for a rigid carbon fork that won't completely mess up the geometry? Or, another suspension for for that matter that isn't too expensive (I know, it's relative!).
    TIA for any guidance!
    Bike = Save up to 60% off new Mountain Bikes - MTB - Motobecane Fantom 29 X5 SRAM 3x10SP, WTB TCS Tubeless Compatible, 29er Mountain Bikes
    Geometry = http://www.bikesdirect.com/products/...es/f29-geo.gif
    Pretty sure your XC 30 100mm travel 29er fork is going to have a 500-510mm axle to crown height. You can verify by measuring from the lower headset cup to the center of the fork QR axle.
    465mm is not going long enough. An air fork will allow for a stiffer spring rate & lower weight.
    jrm
    jrm is offline
    Reputation: jrm's Avatar
    try on-one and xplanet. If youd consider steel theres always salsa and surly..
  1. Replies: 8
    Last Post: 04-10-2018, 12:59 AM
  2. Replies: 2
    Last Post: 09-21-2017, 12:56 PM
  3. How to swap my QR axle for a Bolt on axle
    By cummings in forum Downhill - Freeride
    Last Post: 02-13-2013, 05:58 AM
  4. Replies: 2
    Last Post: 10-07-2005, 12:11 PM
  5. Axle to crown questions...
    By SDizzle in forum 29er Bikes
    Last Post: 10-29-2004, 01:32 PM
Members who have read this thread: 22
