Any Recommendations For Moving Up A Grip- Mtbr.com
Results 1 to 10 of 10
    Feb 2018
    Hi,
    I want to move my existing grips up 1.5cm so that I can fit a set of 'Bull Horns' to the bar.
    Any ideas on what I could lubricate or move the grips with, so that when they dry they won't slide?
    Thanks in advance for your help.
    Attached Thumbnails Attached Thumbnails Any Recommendations For Moving Up A Grip-img_0087.jpg
    Up In Smoke
    Reputation: Train Wreck's Avatar
    Feb 2005
    wd-40
    Jan 2009
    actually, WD-40 works pretty well. it dries fairly fast and leaves the grip sticky on the inside.
    otherwise, water, glass cleaner, etc will work. the best way is an air compressor with a small wedged tip inside the grip. no liquid needed.
    Apr 2020
    hair spray. lubricates enough to slide grips on when wet, dries tacky. been using it for 30 years.
    May 2020
    I've had good luck using Isopropyl alcohol. I actually used a syringe with a small plastic tube to squirt it in between the bar and grip and I was able to move it.
    A compressor would work better if you have one.
    Feb 2018
    Super, thank you very much
    Jan 2009
    Quote Originally Posted by PNW MTB View Post
    A can of Aqua Net is on my work bench too... haven't used it in forever though with the invention of lock-on grips.
    Quote Originally Posted by mack_turtle View Post
    But to get a grip that's already on the bar moving, a compressor is the only solution I know.
    @OP: Personally, I'd cut your grips off and use lock-on ones.
    [WTB] 1987 Cannondale SM800, 20", Pink with airbrushed graphics.
    Reputation: MSU Alum's Avatar
    As mentioned, rubbing alcohol. If the grip is already on, wedge something like a wooden matchstick under the lip, pour a little alcohol on it so it runs under the grip. After a couple of twists, it'll come right off.
    To put it back on, pour a little alcohol in the grip and slide it on quickly, as it will dry fast.
    Years ago, I got tired of fooling with that system and got lock-ons.
    jrm
    jrm is offline
    Reputation: jrm's Avatar
    I use a small screwdriver to pry up the lip of the grip and then slide a syringe filled with rubbing alcohol between the bar and grip to move, remove or replace my esi grips...
    Reputation: Lone Rager's Avatar
    Dec 2013
    If you're using alcohol on ESI or similar, you need tons of it because the grip soaks most of it up.
    What, me worry?
  1. Replies: 19
    Last Post: 03-20-2018, 06:26 AM
  2. Replies: 6
    Last Post: 02-12-2014, 02:56 PM
  3. Replies: 4
    Last Post: 09-20-2012, 10:54 AM
  4. best grip platform pedal to use with power grip straps.
    By package81 in forum General Discussion
    Last Post: 09-11-2011, 10:58 AM
  5. Grip recommendations for XO grip shifters?
    By Jank in forum General Discussion
    Last Post: 08-25-2006, 12:23 PM
Members who have read this thread: 47
