29" Fox 32 stepcast Factory vs Performance Elite vs Performance- Mtbr.com
Results 1 to 5 of 5
    Sep 2015
    Hello all,
    I am building up a light weight xc bike and looking at suspension forks and cannot find out the weight difference betweeen a Fox 32 stepcast boost Factory vs Performance Elite and Performance model.
    The fox website lists the weight of a Factory model as 1387g for the 27.5 version. Then I see a listing on ebay lists a Performance model of a 29er fork as 1500g.
    Is there really only 113 grams difference between the two or is one with axle and one without.
    I'd like to know the apples to apples weight comparison of Factory vs Performance vs Performance elite. Does anyone know or have any ideas how I could find out the answer?
    Thx Lloyd
    Sep 2015
    This was answered over at weightweenies. Apparently the only difference between factory and performance elite is the kashima coating - weight is exactly the same. The factory and performance elite have Fit4 internal dampers and the performance has grip which makes the performance model about 100g heavier.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Quote Originally Posted by lloydus View Post
    I'm not sure that is correct. It's my understanding that the performance models use a different aluminum alloy stanchion material and more of it has to be used due to it being weaker, resulting in the weight difference. 100g of difference is a LOT for a damper, especially on a 32SC.
    Jan 2019
    Perfomance elite and factory are the same, save for the factory has kashima.
    Step cast has the lighter lowers. I think you can still get factory spec without step cast lowers, that will be the weight difference is
    Sep 2015
    Quote Originally Posted by Tom Howard View Post
    Thanks much. I think I know what I need to know now.
    Lloyd
  1. 34 Stepcast Performance Elite
    By La Nada in forum Shocks and Suspension
    Last Post: 3 Weeks Ago, 10:30 AM
  2. 2018 Fox 32 Stepcast Performance Elite 3 Position manual lockout Lever ?
    By Ranger Pride in forum Shocks and Suspension
    Last Post: 12-08-2018, 08:30 AM
  3. Where are all the non-boost Fox 32 Stepcast forks?
    By RadBartTaylor in forum Shocks and Suspension
    Last Post: 05-28-2018, 08:40 PM
  4. Fox 32 27.5 Stepcast fork $299 @ JensonUSA
    By TDLover in forum Where are the Best Deals?
    Last Post: 02-09-2018, 04:33 PM
  5. Fox 32 Stepcast in 110 or 120mm?
    By cuzitsmyUSofwtvr in forum Weight Weenies
    Last Post: 05-09-2017, 06:17 AM
Members who have read this thread: 68
