2021 Fox 34 Grip2- Mtbr.com
Results 1 to 11 of 11
    Jan 2016
    2021 Fox 34 Grip2
    Just saw this and am curious if we can retrofit the grip2 damper to recent fit4 forks. I would be very interested if so but see no info
    Formerly PaintPeelinPbody
    Reputation: PHeller's Avatar
    Dec 2012
    Yep. No chassis changes with this move, so should be a drop-in deal.
    Work - Utility GIS Analyst
    Party - 2019 Guerrilla Gravity Revved Trail Pistol Sz 3
    Jan 2016
    Good info---may call my lbs to see what they know and if parts are available-----surprised there has not been a ton of chatter on this given all the normal fork talk and the good reviews generally of grip 2
    Id be interested in whether this could fit in a PIKE.
    Dec 2012
    That'd be tough because the top cap is a pretty different size (not sure where you'd find that 1mm of material) and you'd need to make new retainers for the bottom of the stanchion.
    The GRIP2v2 is good, but worth the trouble of stripping out a completely fine Charger 2.1? I'm not so sure.
    Now, sticking one in a MRP Ribbon or Revelation is a different story.
    Nov 2018
    I currently have the GRIP damper and am wondering if upgrading to this will help with small bump sensitivity. I find the fork with the GRIP 1 damper is pretty harsh compared to other forks I've tried.
    Nov 2018
    ordered one
    I just ordered a Fox 34 2021 GRIP 2 damper for my 2019 Fox 34 performance fork. Will report back after I trying it out.
    Sep 2018
    Quote Originally Posted by DocFPV View Post
    I know I am months late responding to this, but I was working on my friend's bike a few weeks ago and his Fox 34 with the GRIP damper felt horrible. I took it apart and the air piston was coated in ridiculous amounts of grease. After cleaning and lightly greasing the air piston assembly it was a whole different fork. Not sure why it came from the factory that way, but I would check this on any Fox fork that was feeling harsh.
    EDIT: I should clarify that this was a 2019 Fox 34, not the 2021.
    AOK
    AOK is offline
    Reputation: AOK's Avatar
    Where did you order from?
    Reputation: MSU Alum's Avatar
    I have a 2021 Fox 34 Grip 2 in a 140mm.
    I LOVE IT!
    BTW, don't expect to be able to tell the difference between various compression damping settings in your garage. It has to be ridden to tell the difference.
    Nov 2018
    Quote Originally Posted by AOK View Post
    I just got my local bike shop to order it directly from Fox Canada.
  1. 2021 Fox DPX2 update
    By miles of pain in forum Shocks and Suspension
    Last Post: 04-16-2020, 08:12 AM
  2. 2021 Fox Forks (especially 49)
    By Lelandjt in forum Shocks and Suspension
    Last Post: 04-10-2020, 02:17 PM
  3. Seeking Input: Fox 34 Vorsprung vs Fox 36 GRIP2
    By GiddyHitch in forum Shocks and Suspension
    Last Post: 09-20-2019, 10:03 AM
  4. New coil shock from FOX - 2020/2021 leaked images
    By dmcd38 in forum Downhill - Freeride
    Last Post: 07-26-2019, 02:41 AM
  5. Replies: 4
    Last Post: 01-28-2015, 12:16 PM
Members who have read this thread: 253
