Results 1 to 15 of 15
    Ride Fast Take Chances :)
    Reputation: alexbn921's Avatar
    2019 Schwalbe Magic Mary 29 x 2.6 ADDIX Soft
    My next front tire. Doesn't seem to be officially released, but it's in stock in Germany.
    https://r2-bike.com/SCHWALBE-tire-Ma...Easy-Apex-2019
    Making shit harder than it needs to be isn't awesome, it's just...harder.
    Anytime. Anywhere.
    Reputation: Travis Bickle's Avatar
    Sproing.
    I got some bad ideas in my head.
    Mr. Buck E. Fikes
    Reputation: Oh My Sack!'s Avatar
    Finally! I've been surprisingly very pleased with the NN's SpeedGrip in this size config on the front and back but was concerned about the front end traction. It's doing great! I'm experimenting on i30's and really would like to get them on some carbon i35 hoops though to see how they run. This MM will make for an even better combination on my trails, especially if we actually see some rain this year.
    Is dang happy!
    Reputation: Mr. Doom's Avatar
    The 2.6" Nobby Nic is not much bigger than a 2.5" Minion. I am guessing the casing on the Magic is the same as the Nic and it will not be a particularly wide tire but I could be wrong.
    For high speed stuff the 2.5 Minion is still the gold standard and if you can squeeze a 3.0 Minion in your fork it will grip the gnar like a fatbike tire.
    The wheel is a extension of the foot
    I bet your right the they share the same casing. The casing on the 2.6 is much wider than the DHF 2.5 and about the same height.
    Mr. Buck E. Fikes
    I gave up on Minion because they're so far off with nominal sizing. My 2.6 NN's do not go as wide on i30's as I expected them in contrast to how wide all my other Schwalbe sizes go but I think it will increase closer to the nominal, if not exceed it on an i35 hoop. The 2.5 Minion on an i30 isn't as wide as a 2.35 Schwalbe would be on the same hoop.
    WNC Native
    Reputation: nitrousjunky's Avatar
    Glad to see this tire coming!
    "I ride to clear my head, my head is clearer when I'm riding SS. Therefore, I choose to ride SS."~ Fullrange Drew
    Reputation: Bradical's Avatar
    Feb 2013
    Iím running one now....I ordered 2 from Schwalbe USA.
    Great tire
    Quote Originally Posted by Bradical View Post
    Great tire
    Any size measurements and feedback vs the 2.35?
    Oct 2015
    Quote Originally Posted by Mr. Doom View Post
    I totally disagree. Minions are wide on the knobs but narrow in the casing. They also don't grip like a Mary on all surfaces, they lack any transition which is important sometimes on flat/off camber and generally loose corners.
    Now the Assegai, that's a good Maxxis tyre.
    May 2010
    im running 27.5x2.8 mm front / butcher grid rear on my levo and its fantastic in the loose wet conditions here, i ordered some 29 x i35mm spanks im going to try the Assegai 29x2.5's untill the new eddy currents are available. atleast the 29x2.6 rear eddy current with a MM front.
    Reputation: MSU Alum's Avatar
    Regarding sizes, here are some measurements off of several tires and rim widths, all at 20 psi.
    27.5x2.6 Nobby Nic Addix on Ibis 742 (35mm inner). 2.57"
    27.5x2.6 Nobby Nic Addix on Ibis 735 (29mm inner). 2.49"
    29x2.35 Nobby Nic Addix on I9 270 (27mm inner) 2.38"
    29x2.3 DHR2 on TRX1 (30mm inner) 2.31"
    29x2.3 DHF on TRX1 (30mm inner) 2.30"
    That's carcass widths on all. In all 5 of these combos/pressure the knobs were no wider than the carcasses.
    yohyatt
    Reviews
    Great tire
    All the 27.5 x 2.6 reviews say the spacing is too far apart on the 2.6. And isnít optimal on hard pack berms. Too tractor like and only for deep sand. I wonder if they fixed that on this release?
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    I ordered 4 of these (29 x 2.6 MM) for my wife and I to take on a riding roadtrip to the PNW the past 2 weeks.
    They didn't show up in time -- not til 3 days after we'd left.
    And they aren't much use to us in the desert.
    Thus, I have 4 of 'em for sale. NIB. Send PM if interested.
    Replaced front 2,35 MM 29 with 2,6 MM, and it is a big difference in size. Rolls over very well, and grip is great on wet surfaces. By 1 bar, it is not so accurate in high speeds, but definitely great option for winter. New Hans Dampf 2,6 speedgrip works great on rear too. On asfalt I noticed rolling difference, but in the forest not so much, if at all, and this is great set of super grippy tires. Also the fork feels super smooth now, since tire is providing some extra softness.
  1. Anyone tried Schwalbe's new Addix compound?
    By Suns_PSD in forum Wheels and Tires
    Last Post: 01-26-2018, 12:37 PM
  2. Replies: 24
    Last Post: 12-26-2017, 09:41 AM
  3. Replies: 1
    Last Post: 09-22-2017, 06:19 AM
  4. Replies: 0
    Last Post: 08-25-2017, 05:55 PM
  5. Schwalbe new addix tyres
    By rave81 in forum Wheels and Tires
    Last Post: 07-31-2017, 07:49 AM
Members who have read this thread: 184
© Copyright 2018 VerticalScope Inc. All rights reserved.
