165 mm new crank for Trek Fuel EX 2018 9.8 - DUB not fitting- Mtbr.com
    May 2020
    Hello,
    I bought a Trek Fuel EX 9.8 2018 last year with SRAM Descendant 7k Eagle, direct mount 175mm.
    I just ordered the same model but 165mm length but it doesn't fit. I think the difference is the DUB new structure.
    Can somebody confirm if I can put a adapter or need the exchange the DUB model with a older one I suppose that will fit ?
    Mart
    Reputation: huckleberry hound's Avatar
    Feb 2015
    You need to replace the bottom bracket with a pressed fit Dub BB. Or find a set of 165nn GXP cranks which may be hard to do since they were discontinued two years ago.
    Change begins by doing something different.
    May 2020
    Thanks for the response.
    Is it like this : https://www.worldwidecyclery.com/col...it-mtb-89-92mm
    Thanks again
    Feb 2015
    Yes that one will do. You are also going to need a bearing press to install it. You may be able to find the drifts only and use some allthread, washers and nuts to install it to save some money. That or take it to the lbs to have them install it.
  1. Replies: 13
    Last Post: 03-17-2020, 09:18 AM
  2. Replies: 5
    Last Post: 05-21-2018, 03:10 PM
  3. 150 mm vs 165 mm bikes
    By cmrocks in forum 27.5
    Last Post: 03-14-2015, 03:57 PM
  4. Replies: 2
    Last Post: 10-08-2014, 10:46 AM
  5. Trek Fuel Ex 8 vs. Fuji reveal 2.0 vs. Trek Fuel Ex 6
    By WilliamM10 in forum Beginner's Corner
    Last Post: 01-15-2012, 06:19 AM
Members who have read this thread: 35
