Page 5 of 5 FirstFirst 12345
Results 401 to 404 of 404
  1. #401
    Dec 2013
    Quote Originally Posted by prj71 View Post
    Your center of gravity is about 4 ft off the ground. The lower bottom bracket making the bike corner better or feel more stable is a myth. But it is the difference between getting a pedal strike and not getting a pedal strike.
    Dropper post will solve your feelings of instability.
    From my perspective your CoG is at your feet on the pedals.
  2. #402
    Dec 2018
    Quote Originally Posted by Suns_PSD View Post
    The CG of your body when you are standing up is roughly a couple of inches below your navel. It is dependent on your body position of course, and will be a bit in front of your waist/navel when you're in typical mountain biking position.
    For a given amount of leg "compression" (i.e., a specific set of ankle/knee/hip angles), a higher bottom bracket relative to the ground will move your CG higher a corresponding amount. To get the same CG height above the ground with a higher bottom bracket, you need to compress your legs more to lower your body relative to the bottom bracket. Thus, a bike with a higher BB may make you feel taller and less steady.
  3. #403
    Jan 2009
    I like "taller and less steady" as I allows me to throw the bike around more easily. Too "steady" makes the bike feel like it's velcroed to rails- handles great on mellow terrain in a straight line. Not so good for vaulting over rocks.
  4. #404
    Oct 2015
    Quote Originally Posted by mack_turtle View Post
    Allows a quicker change of direction as well. Low is great for a single turn, higher is better for S turns. This is to a point. Too high will feel cumbersome i prefer 13.5 to 13.75 for mid travel bikes.
  1. Replies: 9
    Last Post: 2 Weeks Ago, 08:00 AM
  2. 2019 Anthem 1 (27.5) vs 2019 Spark 950
    By squidattack in forum XC Racing and Training
    Last Post: 09-07-2018, 11:21 AM
  3. stump jumper 2019 expert or SC Bronson v3 s 2019
    By coming_in_hot in forum 27.5
    Last Post: 08-03-2018, 09:49 AM
  4. To sit or not to sit?
    By paulney in forum California - Norcal
    Last Post: 07-09-2015, 10:25 PM
  5. PVD Testing...testing...testing
    By pvd in forum Frame Building
    Last Post: 06-09-2008, 11:56 AM
Members who have read this thread: 1223
