What tubes in the Weirwolf Lt 29er tires- Mtbr.com
Results 1 to 10 of 10
    Reputation: bigtymerider's Avatar
    This may be a dumb question but do you just use a 2.3 wide tube and it spreads out or are there tubes wide enough on the 29er platform for the 2.55? And if so can someone please direct me?
    Live Large
    Harmonius Wrench
    Reputation: Guitar Ted's Avatar
    Quote Originally Posted by bigtymerider
    Any 29"er tube should work fine.
    Any 26"er tube that covers that width should be fine.
    In fact, I once had to put in a 35mm hybrid tube in a WW LT in a pinch and even that worked! (But I wouldn't recommend anyone else to try that.)
    Riden' an Smilin'
    Guitar Ted
    Blog
    RidingGravel.com
    ballbuster
    Reputation: pimpbot's Avatar
    I use Lunar Lites
    Best $6 a wheel evar!
    jdg
    jdg is offline
    I just use 26" tubes in mine, in the 2.0-2.3 range.
    Reputation: boomn's Avatar
    yes and no. The "2.55" Weirwolf is really a 2.3 anyway, but you can use a smaller tube than that without problems too (26x2.1 for me)
    Reputation: Johnny Chicken Bones's Avatar
    It's the way I run them but I wouldn't suggest it-
    I use a 26" x 2.1 thin walled tube in my WW LTs. Only problem is getting a patch to stick after they are so stretched out.
    Patches? Tubes? Yes, I'm that guy still in the stone ages of air retention.
    --------- __o
    ------- _`\<,_
    Running is for prey.
    how about.... no tubez?
    Rider and Wrench
    Reputation: knottshore's Avatar
    Quote Originally Posted by ghostbear51
    I have to agree they do well with stans... and tubeless
    I just ran a pretty std 29er tube in the past though- they are closer to a 2.35 or so but the smaller or thinner or 26" may reduce your overall weight, if not... stick with the right/closest size-
    I Just wish I could ride more!
    i heart singletrack
    Reputation: mgersib's Avatar
    that's what i've been doing for two seasons now. i've had great luck and it's a way better tire from a traction and trail feel standpoint when running tubeless.
    I like bikes
    Stayin' Puft
    Reputation: canyonrat's Avatar
    Specialized Turbo 29er tubes...good to go WW on Gordo...and all that lovely talc that just makes it "Special" is included.
