• 09-14-2009
    bigtymerider
    What tubes in the Weirwolf Lt 29er tires
    This may be a dumb question but do you just use a 2.3 wide tube and it spreads out or are there tubes wide enough on the 29er platform for the 2.55? And if so can someone please direct me?
  • 09-14-2009
    Guitar Ted
    Any 29"er tube should work fine.
    Any 26"er tube that covers that width should be fine.
    In fact, I once had to put in a 35mm hybrid tube in a WW LT in a pinch and even that worked! (But I wouldn't recommend anyone else to try that.)
  • 09-14-2009
    pimpbot
    I use Lunar Lites
    Best $6 a wheel evar!
  • 09-14-2009
    jdg
    I just use 26" tubes in mine, in the 2.0-2.3 range.
  • 09-14-2009
    boomn
    yes and no. The "2.55" Weirwolf is really a 2.3 anyway, but you can use a smaller tube than that without problems too (26x2.1 for me)
  • 09-14-2009
    Johnny Chicken Bones
    It's the way I run them but I wouldn't suggest it-
    I use a 26" x 2.1 thin walled tube in my WW LTs. Only problem is getting a patch to stick after they are so stretched out.
    Patches? Tubes? Yes, I'm that guy still in the stone ages of air retention.
  • 09-14-2009
    ghostbear51
    how about.... no tubez?
  • 09-14-2009
    knottshore
    I have to agree they do well with stans... and tubeless
    I just ran a pretty std 29er tube in the past though- they are closer to a 2.35 or so but the smaller or thinner or 26" may reduce your overall weight, if not... stick with the right/closest size-
  • 09-14-2009
    mgersib
    that's what i've been doing for two seasons now. i've had great luck and it's a way better tire from a traction and trail feel standpoint when running tubeless.
  • 09-14-2009
    canyonrat
    Specialized Turbo 29er tubes...good to go WW on Gordo...and all that lovely talc that just makes it "Special" is included.
