Results 1 to 5 of 5
    What size tires max for 2012 Specialized Epic Aluminum 29" frame?
    I got a totally stock 2012 Specialized Epic Aluminum bike recently, a 29er. The tires on it now are old 1.95" and very warn down. Reviews on the bike indicate that it originally came with 1.95". I gotta get new tubeless tires. Most are wider today, and I'd like to go wider for the traction. I'd estimate that the frame is about 2.5" wide at the max width area of the tires, if that makes sense. In other words, 2.5" tires would just about be riding against the frame and/or forks if I put that size on... Wondering what size should be the max width I should go with and be safe, not have mud lock up the front tire and send me over the handlebars. A local dealer sold me some new 2.3" or so (haven't installed them yet) and I'm thinking that's probably too wide so I'll take 'em back. Wondering what size should be the max width I should go with for this bike. Thanks in advance for your help.
    Dave
    Reputation: protsi's Avatar
    Dec 2010
    Quote Originally Posted by dniemeye View Post
    Dave
    Dave. I bet the 2.3 fit without any problem. But you have to think what do you run more. Wider tire means more friction less speeds, if you runs trails I donít go wider than 2.2, if cross country 2.3 and up depending, but is matter of taste
    Sep 2014
    Dave
    2.25 is the widest you can sensibly run without rubbing. You can fit a 2.35 in the rear of an epic, but it'll rub on the inside of the chainstays while cornering + debris etc.
    This is on the standard Roval Control SL wheels.
    Jan 2016
    On my 2013 Epic Comp I'm running a 2.4 Ardent up front...
    flatworm
    Nov 2018
    2012 Epic Alu. 21mm internal rims (stock), 2.6 Nobby Nic rear clears stays by about 6mm, barely clears FD cable clamp bolt by 4mm in rear. Front 2.6 Butcher has plenty of clearance in Reba. Nobby Nic is slightly larger than Butcher at 62 vs 60 mm. No rubbing under load noted so far.
    Running tubed since I'm concerned about burping, not sure if tire is folding in use or not. Sometimes feels loose at slow speeds but seems rock solid at speed. 19F 21R for combined weight of 210 lbs. Has fantastic shock absorption and traction especially climbing.
  1. Replies: 29
    Last Post: 09-29-2015, 07:44 AM
  2. Replies: 26
    Last Post: 06-21-2012, 07:16 AM
  3. 2012 Epic Comp 29er vs. 2012 Epic Expert 29er
    By mark43 in forum Specialized
    Last Post: 10-04-2011, 11:24 AM
  4. "Kliane" "Klein" "Quasi Moto" "Paul"
    By stan4bikes in forum Vintage, Retro, Classic
    Last Post: 08-20-2007, 03:36 AM
Members who have read this thread: 32
