Weirwolf LT's on Arch rims?- Mtbr.com
Results 1 to 9 of 9
    Nov 2006
    Has anyone had any time on this set up? I just ordered a set of weirwolf lt's and didn't notice that the recommended inside rim width is 21mm. The arch is 19mm. Will I be alright using them on an aggressive trailbike on these rims?
    Reputation: can't get right's Avatar
    May 2005
    Yes, and yes.
    Reputation: LyNx's Avatar
    Won't be a problem, I've run it on a Alex TD17 without issues, but you won't get the full potential of the tyre.
    Quote Originally Posted by Harold
    You're doing mtbr wrong, you're supposed to get increasingly offended by the implications that you're doing ANYTHING wrong.
    Rider and Wrench
    Reputation: knottshore's Avatar
    I have Arch's and Weirwolf's.... but the Weirwolf's are actually on a set of Shimano XT Tubeless wheelset not the Arch's. The Shimano rims are only 23.5 wide (outer)- I have been running them for about 5-6 Months on a full rigid - no issues. I ride mostly rocky rooty XC so no super Aggro but I run about 210# with gear so I am not too easy on them.
    I can't say either way if the performance is better of worse compared to it on a wider rim but traction is great and no burping issues run tubeless w/stans-
    I Just wish I could ride more!
    Reputation: ccornacc's Avatar
    I have one as a front tire on my FS and it holds up well. It's mounted up with Caffelatex and it holds air great. I am 180 and run it at about 28 psi on all types of CO terrain.
    I've been running WWLT on an arch for awhile now. Not only is it a great setup but I've had no problems whatsoever other than my normal personal shortcomings...
    Reputation: eric_syd's Avatar
    Anyone usinng them tubeless with either Stan's, ghetto or Gorilla ?
    I have the same set of rims and have not tried the WW yet.
    Reputation: CCSS's Avatar
    You're good to go
    I've run a WW LT on an Arch rim since January. Running tubeless at 22 lbs pressure, rigid, *lots* of rocks and roots, but no burps or flats. Ran the same tire on a much wider Salsa Delgado previously (tubed), and like it better on the Arch with the lower pressure.
    Nov 2006
    Awesome. Now I feel better. Thanks for the quick reply's.
