Tyre touching front derailleur- Mtbr.com
Results 1 to 11 of 11
    Aug 2010
    Greetings!
    Bought a new pair of tyres, had no idea they were so huge. It would be a hell sending them back, and i want to keep them anyway. I really dont want to switch back to my previous hybrids. Any suggestions?
    Thanks in advance.
    Attached Thumbnails Attached Thumbnails Tyre touching front derailleur-2424.jpg
    Reputation: singlespeedstu's Avatar
    This SLX front mech should give you a bit more room.
    http://www.chainreactioncycles.com/M...?ModelID=28027
    poser Administrator
    Reputation: rockcrusher's Avatar
    Aug 2003
    sram front derailleur also has better clearance. Best solution besides going 1x9
    MTBR Posting Guidelines
    calories>electrons
    Bedwards Of The West
    Oct 2007
    two options:
    1) Ditch the front derailleur.
    2) Use tires instead of tyres. Using the Y instead of the I causes swelling, as evidenced by the heads of people who drive Land Rovers, which also use tyres instead of tires.
    (no excuse for that either)
    Reputation: Sunburst576's Avatar
    CommuterBoy....I couldn't have said it better
    Aug 2010
    I´m from sweden, sry > <
    Reputation: s0ckeyeus's Avatar
    Go to a traditional high clamp front derailleur (bottom swing). That should clear up the issue.
    P.S. Tires or tyres...same thing.
    Oct 2007
    I kid, I kid. I used to have a Rover and I'd crack up reading the manual. There were Y's and U's everywhere!!
    I have a Sram front D and it definitely has better clearance than that, even though it's a low clamp.
    Always Learning
    Reputation: BruceBrown's Avatar
    Quote Originally Posted by 000111
    Greetings!
    Thanks in advance.
    If the suggestions of different FD's doesn't do it....
    Certain frames can cause this issue when running a big fat rear tire. The 2 x 9 or 2 x 10 set up (as long as it is a legit one where the inner ring sits out a bit further from the BB shell than a granny ring in a triple set) with a Dura Ace FD gives much more clearance and with the new 11-36 cassettes (yes, a new lightweight 11-36 is available), your gearing still has a very nice range to it.
    BB
    "that guy"
    I had the same exact problem when I built my frame. Now I have an extra XTR laying around not getting used.
    I tried pretty much every low clamp I could find Sram, xt, slx, nothing new works.
    If you can pull off a high clamp that will work, otherwise try to find an XT from a few years ago. Here are the before and after shots of mine.
    Sorry the new pic isn't great. it's the best one I have at the moment. The older XT has much less junk in the trunk and will give you at least 5-10 mm of room back there.
    banjo plunker, wrench
    Reputation: swaneedawg's Avatar
    Quote Originally Posted by singlespeedstu
    I just installed a deore version of the traditional clamp, top swing, dual-pull front dérailleur...and there is a little room 3-5mm for the dual-pull arm to clear a 2.2 WTB Wolverine tire in the rear of a Gary Fisher 29er!
    any time spent riding a bicycle is re-cycled goodness....
