Two Gears- Mtbr.com
Results 1 to 12 of 12
Thread: Two Gears
    el Camino
    May 2012
    Two Gears
    I ride a single speed in the steepness of Idaho. I'm mostly fine, cuz of my insane strength and the raw power generated deep in my beer gut. But there are moments when I sure would like a granny gear. Is anyone doing anything interesting in this R&D department? I feel like these huge cassettes and derailleurs are getting pretty stale and clanky. All I need is a climbing gear and an "everything else" gear.
    EAT MORE GRIME
    Reputation: 127.0.0.1's Avatar
    Nov 2013
    two speed kickshift disc hub with appropriate front ring
    https://road.cc/content/review/33373...-kickshift-hub
    Sturmey-Archer | S2K Red
    Gear 1 - 100% (Direct Drive)
    Gear 2 - 138% (Gear 1 + 38%)
    "Put your seatbelt back on or get out and sit in the middle of that circle of death." - Johnny Scoot
    Cycologist
    Reputation: chazpat's Avatar
    This post is a natural product. Variances in spelling & grammar should be appreciated as part of its character & beauty.
    Reputation: Redlands R&C's Avatar
    Dec 2013
    I've thought about running a GX/X01 DH 7 speed setup on my bike for a while now, the ratios on those 7speed cassettes are 10-23/12-25 if I recall.
    Could also run a truncated/modded homemade cassette with 3-4 Surly SS cogs, a Zee/Saint rear derailleur and a friction shifter.
    Silly bike things happening.
    Chain tensioner and 2 rings in front, no der. Flick the chain to the small ring with your toe to downshift if you don't use a bash ring.
    Oct 2018
    I'd second a 2nd chain ring and front derailleur. I know a roadie with a 2 speed road bike, single gear with 2 rings.
    WillWorkForTrail
    Jun 2012
    Search "dingle speed" - I seem to recall a conversation about this a while back.
    Jan 2009
    the idea behind dinglespeed is that you have two gear combos that use the same length chain. you'll still need a single-speed tensioning option of some sort- sliders, EBB, track ends, or a tensioner. it will take a bit of fiddling to change gears, but you can do so at the top of a big climb while trying to catch your breath.
    EAT MORE GRIME
    Nov 2013
    dinglespeeds take fiddling. often stopping.
    so if you want a hassle free ride w/o stops
    a kickshift is a) no tensioner b) no need to stop c) short learning curve can shift it about anytime anywhere
    mbtr member
    Reputation: scottzg's Avatar
    Maybe a retro-direct system?
    "Things that are complex are not useful, Things that are useful are simple."
    Mikhail Kalashnikov
    Reputation: CougarSlayer's Avatar
    Aug 2015
    Looks for an old Hammerschmidt crankset on ebay
    jrm
    jrm is offline
    Reputation: jrm's Avatar
    I built a 2spd kick back hub into a SS CX bike and after a couple of rides i replaced it with the SS wheel. Mainly b/c the extra gear was only about 33% and it was easier to remain standing using the taller of the two gears. I noticed a bit of hub drag and lapses between shifts which i didnt like b/cit messed up my cadence. I have a rigid niner with a 1 x 10 with a 30/42 granny i really like b/c it has so much range.
  1. Gears on No Gears?
    By bing! in forum Downhill - Freeride
    Last Post: 11-13-2014, 01:44 AM
  2. Two Days....Two Rides....Two Vids
    By Jaydude in forum Colorado - Front Range
    Last Post: 03-08-2011, 05:37 PM
  3. Replies: 4
    Last Post: 03-08-2011, 11:25 AM
  4. Gears or no gears?
    By no_lix in forum Beginner's Corner
    Last Post: 03-18-2007, 03:50 PM
  5. Gears, Gears, and More Gears
    By OneEyeMan in forum Singlespeed
    Last Post: 09-05-2006, 06:38 PM
Members who have read this thread: 112
