Turning Out My Trek X-Cal Hardtail- Mtbr.com
Results 1 to 22 of 22
    May 2019
    In May 2019, I bought a 2019 Trek X-Caliber8 hardtail. I am originally from Texas but moved to Colorado in March. I've always enjoyed hardtail but never did anything more than bland Texas parks with the most basic trials.
    Well, since moving to Colorado, the biking has been so much more fun. Which started me on the path towards upgrading the bike to get just a bit more out of it.
    So far, I've done:
    • Mounted pair of red RaceFace Chester flat pedals
    • Swapped 160mm Shimano MT200 standard rotors for Shimano IceTech 180mm rotors with IceTech pads
    • Converted Bontrager Kovee wheels to tubeless
      • replaced Bontrager XR2 tires with Maxxis Minion DHFs
    • Fitted GoPro Blendr stem cap
    • Switch from 2x10 to 1x10
      • RaceFace Ride 36/22 chainrings dropped for RaceFace 104 BCD Narrow Wide 30T chainring (red anodized)
      • new KMC x10 chain
      • SunRace 11-42T 10sp rear cassette (not yet installed)
      • Removed front derailleur and cabling
    • Replace grips with graphite Odi Elite Pro lock-on hand grips
    • Replaced Odi grips with LizardSkinz North Shore Lock-On grips
    • eThirteen TRS+ Chainguide with bashplate and ISCG5 adapter plate
    On the to-do list:
    • PNW Components Rainier IR 125mm dropper post with Puget MTB lever
    • Some tape solution to cover internal-cable Frame holes vacated during 1-by conversion
    Some pics:
    2019 Trek X-Caliber 8
    2019 Evil Wreckoning LB
    May 2019
    While putting in the new chain ring and removing the front derailleur, I noticed this little tidbit. I have no idea what happened to the trigger cover of the my rear shifter?!
    ...guess I'm in the market for a new rear shifter. lol
    Other pics:
    Now taking suggestions on how to cover up the internal cable holes
    Turning Out My Trek X-Cal Hardtail-img_3206.jpgTurning Out My Trek X-Cal Hardtail-img_3207.jpg
    I hate chain slap
    Jun 2014
    Leave the top hole open for your dropper cable.
    May 2019
    I was thinking that. But wasnít sure if the seat/down tube angle was too steep to allow the cable to function.
    May 2019
    Went to Village Bicycles (part of Epic Outdoors) in Colorado Springs and they were very cool and friendly. Very helpful in finding some tools I was needing and even hooked me up with a replacement derailleur shifter cover that fell off for free!
    So as of now, the 22T chainring is finally gone. Will be putting on the 11-42T cassette tonight. Spoke with eThirteen about a BB mount lower chainguide/bash guard combo. Might even mount a low direct chain guide to the vacant e-type derailleur mount.
    Reputation: Lone Rager's Avatar
    Dec 2013
    In the second pic from the last, is that a hole in the seat tube to run an internal dropper cable? If so, you'd run it into an upper hole in the down tube, out a lower hole in the down tube and than up into the seat tube through that hole. The radius of the bend in the cable between the down tube and seat tube will be fine.
    FWIW: I like a smaller rotor in the back...less easy to lock up the rear wheel. All the braking power is in the front anyway. I find IceTech rotors go out of true more and contribute to bite point wander. I prefer the one-piece stainless steel rotors. No need for Ice Tech pads either.
    What, me worry?
    May 2019
    So I have the front chain ring and rear cassette on. Shifts and drive is smooth albeit chatty. The only problem I see now is that the current rear derailleur isn't gonna work. When switching to the 42, the derailleur cage bumps right up to the cog.
    I'm wondering if I could get away with getting an 11-speed rear derailleur and setting the limiting screw to prevent over shifts. I just don't know if I can find a 10-speed derailleur that can fit a 42T cog.
    May 2019
    Just bought a Shimano XT RD-M8000 GS 11-Speed rear. Fingers crossed.
    May 2019
    New XT8000 GS derailleur is on and shifts perfectly! Kudos to Bicycle Village in Colorado Springs for the adjustment help. They even solved the sloppy play in my headset. Turns out Trek uses plastic wedges instead of metal ones.
    Also got word from Jeremy at eThirteen and helped me find a chainguide/bashguard that will work.
    Overall itís been an awesome customer service day.
    May 2019
    Threw on my new Turning Out My Trek X-Cal Hardtail-c554ee26-10a5-47c8-a5cb-e2868fcdf2d2.jpgheadset cap.
    Reputation: Joe Handlebar's Avatar
    Apr 2016
    Just FYI... the M8000 should work with up to a 46 tooth cog. I've heard from some folks they run it without a goatlink...others do for a little more chain wrap on the cogs.
    The member formerly known as Redtires....
    May 2019
    Quote Originally Posted by Joe Handlebar View Post
    I ran it at Vail last week with zero problems. All the gears feel more usable.
    Side note: I threw on the eThirteen chainguide/bash guard last night.
    May 2019
    May 2019
    MY EVIL WRECKONING BUILD HERE---> https://forums.mtbr.com/29er-bikes/t...g-1119517.html
    So with MTB season drawing to a close here in Colorado (and by ďcloseĒ, I mean lifts being shut down to start prepping for ski season. LoL), I find myself already looking forward to next season.
    I decided Iím gonna build my next bike. Hereís my napkin scratchpad notes for my next bike. Iím gonna build out an Evil Wreckoning LB in Fallout Green. Some of the components can already be had on a built one but there are a couple of components that I really like/want. Others were just a PITA to find because of the mind boggling variation/selection/lack of standardization options (specifically the frigging headset options!). Plus thereís nothing better than building something yourself.
    The list is still technically a work in progress. I havenít picked other things like wheelsets, cables, pedals, etc yet.
    FRAME/FORK
    -Evil Wreckoning LB
    -Medium frame
    -RockShox Lyric Ultimate Charger 2 RC2 29, DebonAir
    -160mm travel
    -15x110
    -51mm offset
    DRIVETRAIN
    -Crankset
    -SRAM GX Eagle Dub Boost 148 170 cranks
    -32T chainring
    -Cassette
    -SRAM XG-1295 Eagle 12sp
    -10-50T
    -Rear Derailleur
    -SRAM X01 Eagle 12sp
    -Bottom Bracket
    -SRAM Dub English
    -73mm
    COCKPIT
    -Headset
    -FSA Integrated tapered headset No. 57/68
    -44mm upper
    -62mm lower
    -Upper Bearing
    -30.2x41x6.5
    -36/45 deg
    -Lower Bearing
    -40x51.8x8
    -36/45 deg
    -Headset Spacers
    -XON Carbon spacer kit
    -Handlebar
    -RaceFace SIXC 820 Carbon 35
    -Silver/White
    -35mm rise
    -35mm diameter
    -820mm width
    -Rear Shifter
    -SRAM X01 Eagle 12sp trigger shifter
    -Dropper Post Lever
    -PNW Components Loam Lever
    -Red
    -Stem
    -RaceFace Turbine R35
    -35mm handlebar diameter
    -40mm length
    SADDLE/SEATPOST
    -Dropper Post
    -PNW Components Bachelor Dropper
    -34.9mm diameter
    -150mm drop
    -Seat Clamp
    -Hope Seatpost Clamp
    -Black
    -34.9mm diameter
    -Saddle
    -Spank Oozy 220
    -Green
    BRAKES
    -Front Brakeset
    -Hope Tech 3 E4
    -Black
    -Rear Brakeset
    -Hope Tech 3 E4
    -Black
    -Front Brake Rotor
    -Hope Floating Disc Rotor
    -Black
    -180mm
    -Rear Brake Rotor
    -Black
    -180mm
    -Brake Adapter
    -Post to Post
    Attached Thumbnails Attached Thumbnails Turning Out My Trek X-Cal Hardtail-6ead1393-44f1-4b5f-a2fb-c25cd442c0cf.jpg
    May 2019
    Picked up an Evil Following demo in Drunken Olive flavor today from C3 Bikes in Golden, CO. This bike unbelievable! So smooth. The suspension really does soak up everything. Took it out and was so much faster than my hardtail.
    May 2019
    So this happened on Saturday. Still had fun though. Mountain patrol guys and ER clinic at the base were great and cool as hell.
    Wasnít as bad as this dude that came in right after me though. Lol
    PS: I have zero clue why this crappy forum software keeps rotating my images 90deg when I post them
    Attached Thumbnails Attached Thumbnails Turning Out My Trek X-Cal Hardtail-18076c27-43d4-4881-b8ab-b32794780cd4.jpg
    Reputation: Darth Lefty's Avatar
    Sep 2014
    Aw man! Heal up.
    Good job with the X-Caliber. I test rode one, you are turning yours into the bike I wished it was to begin with
    Jun 2018
    Looks like you are getting into some fun stuff. What is your plan for the X-Caliber now that you have the Evil?
    Paul
    May 2019
    Quote Originally Posted by Frenchman83 View Post
    X-Cal will be the go-to trail bike with family or will just donate it to my son. But I still plan to put some more stuff on it.
    May 2019
    Hardtail was posted for sale. Asking $1000
    Feb 2016
    Quote Originally Posted by AlexTrekbek View Post
    FRAME/FORK
    -Evil Wreckoning LB
    -Medium frame
    -160mm travel
    -15x110
    -51mm offset
    DRIVETRAIN
    -Crankset
    -32T chainring
    -Cassette
    -10-50T
    -Rear Derailleur
    -Bottom Bracket
    -SRAM Dub English
    -73mm
    COCKPIT
    -Headset
    -44mm upper
    -62mm lower
    -Upper Bearing
    -30.2x41x6.5
    -36/45 deg
    -Lower Bearing
    -40x51.8x8
    -36/45 deg
    -Headset Spacers
    -Handlebar
    -Silver/White
    -35mm rise
    -35mm diameter
    -820mm width
    -Rear Shifter
    -Dropper Post Lever
    -Red
    -Stem
    -40mm length
    SADDLE/SEATPOST
    -Dropper Post
    -34.9mm diameter
    -150mm drop
    -Seat Clamp
    -Black
    -34.9mm diameter
    -Saddle
    -Spank Oozy 220
    -Green
    BRAKES
    -Front Brakeset
    -Hope Tech 3 E4
    -Black
    -Rear Brakeset
    -Hope Tech 3 E4
    -Black
    -Front Brake Rotor
    -Black
    -180mm
    -Rear Brake Rotor
    -Black
    -180mm
    -Brake Adapter
    -Post to Post
    Looks like a sweet build! Just to help, since there are many spec variations (as you pointed out), you will want to choose the 22.2 clamp option for your Loam lever, if you're running Hope brakes. You may already be aware of this, but if not, saved you a step! Heal up!
    May 2019
    Quote Originally Posted by PNW_Components View Post
    Thanks for the tip! However, I went with the RockShox Reverb post. My LBS is helping me out with specs on components as I go.
  1. Opinion: 2017 TREK X CAL 9 vs. 2018 TREK X CAL 9?
    By Holographic128 in forum 29er Bikes
    Last Post: 08-30-2018, 03:41 PM
  2. Replies: 38
    Last Post: 07-02-2017, 10:25 PM
  3. Upgrade worth it? 2014 Trek X-Cal 6 to a 2016 X-Cal 9?
    By TheTahoeGuy in forum Beginner's Corner
    Last Post: 11-20-2015, 11:20 AM
  4. 2015 Trek X-Cal 8 or X-Cal 9?
    By V8Interceptor in forum 29er Bikes
    Last Post: 01-24-2015, 07:22 AM
  5. Carve vs Trek X-Cal (Hardtail)
    By iweber in forum Specialized
    Last Post: 01-17-2013, 11:54 AM
