Top Fuel SL Pivot Question- Mtbr.com
Results 1 to 15 of 15
    Jun 2012
    Hey all. Thanks in advance for any feedback.
    I was replacing my pivot bearings on my 2017 Top Fuel 9.8 SL recently and noticed the main frame bearings have a sleeve over the bolt between the bearings. Anyone no why this is necessary, or has anyone removed that sleeve?
    Reason I ask, is that I am chasing an odd click that I think may be coming from the calipers, but I am not ruling out that the sleeve is making a metal on metal noise. I doubt it, but it could be.
    Reputation: Lone Rager's Avatar
    Dec 2013
    The pivot spacer goes between the bolt head and bearing and between the nut and bearing so that the inner races get pinched and secured against the pivot spacer between them. They are required to ensure proper spacing and the bearing don't bind. I put a light coating of grease on the contact points.
    Do the math.
    Jun 2012
    I think we may be talking a out something different. The lower swing arm and the upper pivot assembly’s have a bolt that goes through the seat tube. Inside the seat tube between the bearings is a sleeve that the bolt goes through, That is what I am referring to. You remove that bolt and one of the larger bearings inside the seat tube and that sleeve will fall down to the B.B.
    Do you mean nr 23 in the image? I assume it's supporting the bearings when you are tightening the pivot bolt. Without that spacer, I am guessing you risk either cracking the frame or having the bearings just fall into it when you start tightening.
    Jun 2012
    Yes. It is 23. The bearings have cups so they can only go in to a certain point. I guess there is an argument for lateral support for the seat tube in some ways though.
    Jun 2012
    So fwiw. That noise was not the pivot sleeve. Will be keeping the sleeves in place.
    Jul 2016
    Realize this is an exceptionally old thread, but it seemed like an idea. Took my suspension apart to ship to fox now I'm trying to put piece#17 back in place. Do these go between the shock and the bearing or the nut head and the bearing? If it's the former, I'm at a loss for how to install.
    17 goes between the shock and the bearing. The best way is to use a little grease on the washer to "stick" them to the bearing to hold them in while you install the shock.
    Jun 2012
    +1 on the grease as glue.
    Jan 2018
    How do you pull the #15 bearings? The ID of #23 bushing and bearings are the same. They don't push through, and there is no lip to push them out from the opposing side.
    Thanks for the help to anyone still monitoring this thread.
    Feb 2006
    Quote Originally Posted by KenKinSV View Post
    I would like to know this also
    Dec 2013
    The usual is a bearing puller. Do you have a pic?
    Do the math.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Quote Originally Posted by Lone Rager View Post
    Also known as a blind bearing puller with slide hammer. Every once and a while you can find a kit on amazon/ebay for around $40, it bounces between there and over $100 I believe. I bought one (for $40), it's been useful, but I don't use it all the time obviously. Much of the time, it's still easier to punch the bearing out with a punch and mallet.
    Jun 2012
    I honestly think I used an tube, a delicate vice clamp, and a few delicate taps of a socket to get mine out. worked pretty well.
    Jan 2018
    Trek recommended this tool: https://wheelsmfg.com/presses-tools/...actor-set.html
    I ended up making a bearing puller with a slotted steel sleeve, a flared concrete anchor and a couple of nuts, The concrete anchor expended the sleeve inside the bearing so I could tap them out.
    Attached Thumbnails Attached Thumbnails Top Fuel SL Pivot Question-bearing-tool.jpg
  1. Pivot Mach 429SL Carbon vs Trek Top Fuel 9.8 SL vs Trek Fuel EX 9.9 or ?
    By crcross in forum Bike and Frame discussion
    Last Post: 04-07-2018, 01:58 PM
  2. Trek Top Fuel 9 vs Top Fuel 9.8
    By thisisbenji in forum Bike and Frame discussion
    Last Post: 11-17-2016, 08:12 AM
  3. Top Fuel 9 vs. Top Fuel 9.8
    By Spencerespencer in forum 29er Bikes
    Last Post: 03-28-2016, 09:30 PM
  4. 2008 Top Fuel rocker pivot and seat stay pivot torque?
    By SeaBass_ in forum Shocks and Suspension
    Last Post: 01-22-2012, 07:26 AM
  5. Replies: 0
    Last Post: 01-21-2012, 10:10 PM
Members who have read this thread: 4
