Titus El Guapo 29 prototype- Mtbr.com
Results 1 to 16 of 16
    Reputation: craigstr's Avatar
    Sep 2003
    Apr 2005
    Marzocchi 44 Micro Ti forks set at 140mm, Hope Hoops with Stans Crest rims, Hope Race X2 brakes, Hope Eternity seat post, Maxxis Beaver 2.0 tyres, El Guapo Ancho bars cut to 760mm, On One Thinny pedals.
    AM build: stiff 140 mm forks - check. wide bars - check. Flat pedals - check. Crest rims and beaver 2.0 tires = wtf?
    Originally posted by bucksaw87
    I still fail to see how mustaches, fixies, and PBR are ironic.
    Sep 2003
    Yeah they do things different on the other side of the pond.
    Damn....
    18 Focus Raven Lite
    17 Focus o1e
    17 Yeti ASR-cT
    16 Bianchi Specialissima
    15 Echo Big Deal
    the air is thin up here..
    Reputation: noot's Avatar
    Is it just me, or do those chainstays look VERY long? Like, 18"+ long?
    2017 Transmission Smuggler
    2015 Kona Paddy Wagon
    www.mngnt.com
    Is that Bill rated?
    Reputation: Lord Humongous's Avatar
    I was thinking the same thing Noot.
    Well, it was a good try.
    Mar 2012
    shinnnyyy!
    Harmonius Wrench
    Reputation: Guitar Ted's Avatar
    Quote Originally Posted by noot View Post
    They'll have to be long chain stays if you want all of the following: Clearance for 2.4" tires, (On One, which is also owned by Planet X, is making these in 29"er sizes, so I suspect the El Guapo will have to fit them), clearance for a triple chain ring crankset, and 140mm of rear travel. (Note: they haven't decided, as far as I know, whether to dial that back to 120 in the rear.)
    Change one or two of those parameters and you can shorten up those chain stays a bit. Go for less tire clearance, 120mm rear travel, and a single or double only crank, then you can get waay under 18".
    Riden' an Smilin'
    Guitar Ted
    Blog
    RidingGravel.com
    Happy, in the woods.
    Nov 2008
    Good tire clearance- NEED
    140mm travel- NEED
    Buncha chainrings and a FD- DON'T NEED
    Abba Zaba, you my only friend....
    FM
    FM is offline
    Reputation: FM's Avatar
    Apr 2003
    Quote Originally Posted by thumpduster View Post
    140mm travel- NEED
    Lol, totally agree. If I need to go 3mph, I can get off and walk.....
    rider
    Jan 2005
    Quote Originally Posted by FM View Post
    Dude, I can ride at over 4mph on my Monk with it's 15.3 gear inch granny. But I have gone to a 2x10 setup on the new ride. To each their own.
    Abandoned the 26" wheel in May '03
    rider
    Jan 2005
    I was all set to drool over the proto. I have been pestering Shiggy for a while now about a EG 29er. But after seeing those long appearing chainstays I just want to yawn. Hopefully it is just an optical delusion.
    Quote Originally Posted by Guitar Ted View Post
    I hear ya. This was the first argument for 650b that caught my attention.
    www.mngnt.com
    Reputation: PuddleDuck's Avatar
    Don't be sucked in by the fact that the seat tube doesn't go through the BB, it intersects with a point ahead of the BB. Spec do this too. This makes the front tri look tiny, and the rear look massive.
    Hybrid Leftys aren't real Moderator
    Feb 2005
    Not trying to be an argumentative ******, (since you don't quantify what "long" is in your eyes).
    My Lunchbox is 17.375, and has all the features you mention, as well as 10 mm more travel....
    And to think, when I asked Titus BITD, they pretty much laughed at me, and said a long travel 29er couldn't be done.
    Cannondale Lefty and HeadShock servicing, wheel building, etc...
    www.mendoncyclesmith.com
    bike tester
    Reputation: syl3's Avatar
    it's not the same titus so don't hold the grudge
