Recovering Weight Weenie
Tire weight ramblings...
Just weighed a few of my kevlar tires on the postal scale at work...
Nano - 635 grams
XR - 633 grams
Fast Trak - 623 grams
Ignitor - 620 grams
All this time I thought the XR was super light.
This has got me thinking though..whats the point of the Fast Trak if it's the same as everyone else's?
Good thing is that all the tires listed above are sound, durable, tires.
The new Kendas seem a little sketchy...
Well, your XR, FT and Ignitor are on the high end of the weight range for those models. The XR and Fast Trak are higher volume than other models. All are much lighter than the ExiWolf.
mtbtires.com
45 gone, 15 to go
especially for a guy of your size. You would probably overwhelm them.
 Originally Posted by rryyddeerr
how did this thing get soooo heavy. ive got mine running now and they seem to weigh a ton. Shig, I read on your site theyre like 800g. whoa mamma. is it the casing? its not the tread. its not monstrous, so it cant be that. what makes these things so heavy?
Casing and tread. There is a lot of rubber in the tread. They may have a thick base rubber, too. The base layer is a place that needs to be balanced for durability/toughness and weight/suppleness. Too thin and the tire cuts/punctures easily and the tread can chunk. Too thick and it adds a lot of weight and can make the tire feel dead.
mtbtires.com
Expert Pushing SSer
Seems light(ish) to me for 29" stuff. I am used to 26" stuff and I like things less than 800 g, and usually a lot less (like <650 g). FWIW, I am sort of a closet weight weenie (no I do not like light closets).
the exi
Recovering couch patato
With all those weights so close together, you have the luxory to not worry about weight. Just ride the ones that give you the most confidence. The ideal combination of corner-carving grip and keep-up-with-wife rolling resistance?
I want your XR, be it a front or rear. Mine were like 660g. If Bontrager would make an all-our race version of the XR, ultra-fast casings and even faster rubber, I would not need anything else for dry riding. To make another tire corner faster, I would first have to dig a berm.
uh, uh...oh, i forget
Mine weighed 915 grams! I tell myself that i'm getting a better workout than that guy waaaaayyyyy up front! my fast traks were right at 625 each.
disclaimer: i (NO LONGER) live with my mom...
Reviewer/Tester
My Exi's are : Fast. Light. Tough.
[Pick one]
R.
I guess im just
a big tire weenie cuz i love that 771g exi up front. heck thats still less then the sticky BG i was running on the 26" bike and it rolls better.
They did. It's called the XR 1.8 as demanded by the Fisher race team.
BB
- You may not post replies
- You may not edit your posts
Forum Rules
