>>>>>>>>>For those who blame the RIGs Headset.......HERE is the fix \/
It's not the headset.
The "casting" of the stem is not perfect. The bottom of the stem where it contacts the headset spacers/headset is way off square.
I have a Stein Stem Facing Tool and took off almost 3mm!!!!! to get the bottom of the stem square!
Fixed the problem quickly.
Scoty
 Originally Posted by mikesee
Better suited to non-aggressive 125# gals named Russell.
I ride so slow, your Garmin will shut off.
WOW! Good catch, Scoty.
Never thought of facing a stem.
mtbtires.com
Recovering couch patato
Shhhhhhhh!
Just when Fisher was going to spec something even nicer... :-)
Is the same faulty stem used on the other Genesis bikes, or have only been Rigs been affected?
Good catch indeed. Eagle Eye of the Year!
Scoty
Good catch, and cool, but not entirely true. I never even had my stock stem mounted. I immediately replaced it (O.S. size) so I could use an H-Bar (standard size). Even with aftermarket stem my HS was problematic.
Never heard of a stem facing tool. Cool!
The Stem Facing Tool is a tool you didn't even know you needed until now! It precisely mills the lower face of threadless stems exactly perpendicular to the axis of the steering tube assuring even pressure on the head bearing. This tool prevents binding of the bearing from pressure on only one side of the headset that can cause premature wear and impede accurate adjustment. Includes bushings for 1" and 1 1/8" stems. Part# SF-1
BTI, QPB, UBT have them.
Scoty
Cold. Blue. Steel.
Eagle eye for sure!
it's good to know there is such a tool. i bet many stems are off by at least a little bit. i will check all of mine from now on.
Chris King coincidence. . .
I happened across this last week and your post reminded me of it:
Where does that little plastic washer that came with my headset go?
Answer: The 'scuff washer' is intended to go between the bearing cap and stem or stem spacers to help offset the effects of unfaced stems. It will help reduce the adjustment problems and creaking commonly caused by unfaced stems. (http://www.chrisking.com/tech/tech_FAQ.html).
By reactor in forum Giant
Last Post: 03-21-2005, 12:10 PM
By bikeit in forum General Discussion
Last Post: 02-28-2005, 07:50 AM
By GGAllen in forum Cannondale
Last Post: 11-01-2004, 09:03 AM
By lawhoo in forum Singlespeed
Last Post: 07-11-2004, 04:11 PM
By BanzaiRider in forum General Discussion
Last Post: 05-19-2004, 10:06 PM
- You may not post replies
- You may not edit your posts
Forum Rules
