TanTan FM-299B Long-Term Review, 18.5lb $3000 XC/Trail Build- Mtbr.com
Results 1 to 15 of 15
    Reputation: sissypants's Avatar
    Sep 2016
    TanTan FM-299B Long-Term Review, 18.5lb 00 XC/Trail Build-img_6150.jpg
    The TanTan FM-199B and FM-299B are quality carbon hardtail frames sold consumer-direct from a carbon bike factory in Shenzhen, China. I spent the brutal Michigan winter and damp spring putting the TanTan FM-299B to the test and came away impressed.
    The 299B performs noticeably better than budget AliExpress, eBay, and Amazon hardtails, thanks to its dialed geometry, stiff construction, and attention to detail. It’s a great hardtail at an amazing price!
    FM-199B/299B
    Intended use: XC, Trail, Plus
    Front Travel: 100mm-130mm
    Wheel size: 29x2.35” (FM-199B), 29x3.0”/27.5x3.25” (FM-299B)
    Frame construction: Toray 800 carbon
    Head angle: 69.5o
    Chainstay length: 425mm (FM-199B), 440mm (FM-299B)
    Sizes: 15”, 17”, 19”
    Frameset Weight: 1060g (19”)
    List Price: $459 (I can get it to you for $400), $75 shipping (USA)
    More info: FM-199B, FM-299B
    "Build Thread": https://forums.mtbr.com/26-27-5-29-p...l#post14037259
    I tested my 299B on two different wheelsets with rigid and suspension forks:
    TanTan FM-299B Long-Term Review, 18.5lb 00 XC/Trail Build-img_6188.jpg
    I ran this 29er build after snow melt with a Fox Float 34 SC (120mm travel). It weighs 18.5 lbs and costs ~$3000 if you were to build it from new parts with some deals.
    TanTan FM-299B Long-Term Review, 18.5lb 00 XC/Trail Build-img_5571-copy.jpg
    This 27.5+ build with a RockShox SID RLC (100mm travel) got me through the Michigan winter and did hardpack groomed trail. It costs ~$2500 if you were to build it from new parts, again with a few deals.
    TanTan FM-299B Long-Term Review, 18.5lb 00 XC/Trail Build-bike-copy.jpg
    This was the initial 27.5+ build with a rigid fork, this build cost ~$2000 new and weighed 20.5 lbs (fork A2C length 495mm).
    CONSTRUCTION AND FEATURES
    TanTan FM-299B Long-Term Review, 18.5lb 00 XC/Trail Build-img_9923.jpg
    The 199B and 299B were designed in late 2018 and are manufactured at the TanTan factory in Shenzhen, China. TanTan manufactures the frame at their factory from Toray 800 carbon fiber, which is lighter and marginally stronger than the cheaper and more standard Toray 700 fiber. The 199B and 299B frames are also available on Amazon, eBay, and AliExpress, but I recommend ordering from TanTan directly to ensure you get the best quality control, construction, and aftersales service. They are the original factory for this frame, anyone else is a reseller.
    The FM199B is 29er-specific while the 299B fits 29+ wide 27.5+ tires. The 199B chainstays are 425mm, compared to 440mm on the 299B. Finally, the 199B will fit up to a 36T chainring while the 299B will only fit a 32T chainring. Weights and other geo numbers are comparable.
    TanTan FM-299B Long-Term Review, 18.5lb 00 XC/Trail Build-img_6167.jpg
    Internal cable routing is nicely executed. Ports are satisfactory and seemed to prevent any cable rattle. Routing the shifter cable through the chainstay of my 299B was challenging since the tube was very constricted where clearance was needed for the 32T chainring and big tires.
    TanTan FM-299B Long-Term Review, 18.5lb 00 XC/Trail Build-img_9924.jpg
    Frames come with a BB92 shell, boost rear spacing (172mm x 1.5 pitch axle), tapered headtube, and a 31.6mm seatpost. Frames are tested to 130% of industry-wide SGS safety standards and TanTan quality control is outstanding. 2-year manufacturer warranty is offered and honored.
    TanTan FM-299B Long-Term Review, 18.5lb 00 XC/Trail Build-img_0811.jpg
    A bizarre feature of the 199B and 299B is the rear flat disc brake mount. This is a poor design choice for mountain bikes since a flat-to-post adapter is needed to run calipers paired with almost any flat-bar brake levers. TanTan will include a 160mm rotor flat-to-post adapter with the frame on request.
    GEOMETRY AND SIZING
    Compare the FM-199B and FM-299B geometry on geometrygeeks.bike.
    The 199B has all the numbers to make it a nimble XC weapon. It hearkens to the Scott Scale (see geometrygeeks.bike), though it does average a 5mm longer reach and a 3mm lower stack across sizes. A HTA of 69.5-degrees ensures responsive steering and efficient climbing.
    The geometry should work well with a range of fork lengths, corresponding to 100mm-130mm travel for 29er forks. Compared to my 100mm RockShox SID, my 120mm Fox Float 34 slackened the HTA by 1-degree and raised the BB by a bit, an adjustment that I really liked.
    Unfortunately, there is no XL size for either frame. I’m 6’2” and fit the frame well, but just barely.
    BUILD HIGHLIGHTS
    TanTan FM-299B Long-Term Review, 18.5lb 00 XC/Trail Build-img_6162.jpg
    The Fox Float 34 SC factory fork with 120mm of travel did a great job of handling suspension duties. Compared to Fox Float 32 SC forks I've ridden it feels slightly stiffer, maybe, but also a little heavier. Not the same ultra-efficient XC feel, though it certainly eats up the bumps.
    TanTan FM-299B Long-Term Review, 18.5lb 00 XC/Trail Build-img_6168.jpg
    Rear tire clearance permits for up to 29x3.0 tires on the FM-299B, but I ran just the Schwalbe Rocket Ron 29x2.25" tires for shredding singletrack.
    TanTan FM-299B Long-Term Review, 18.5lb 00 XC/Trail Build-img_6178.jpg
    I ran a mixed drivetrain, with a XTR 1x11-speed derailleur and shifter, SRAM X01 10-42T cassette, PYC SP1101 chain, Race Face Next SL crankset, and OneUp Switch 32T chainring. XTR SPD pedals for power transfer duties.
    TanTan FM-299B Long-Term Review, 18.5lb 00 XC/Trail Build-img_6180.jpg
    This $7 carbon top-cap/black Ti bolt is strangely satisfying (AliExpress link)
    TanTan FM-299B Long-Term Review, 18.5lb 00 XC/Trail Build-img_6181.jpg
    And of course the 680mm 9-degree backsweep -17-degree rise ultralight integrated carbon handlebar needs a mention. It's stiff and awesome! See my review thread here. The handlebar will set you back just $50 and get you lots of attention.
    TanTan FM-299B Long-Term Review, 18.5lb 00 XC/Trail Build-img_6184.jpg
    Braking duties are handled by Shimano XTR Race M9000 brakes and Ashima AI2 160mm rotors.
    The wheelset is from SpeedSafe, an AliExpress seller that I've worked with quite a bit over the last two years. I am running the 22mm inner width 280g rims built to boost DT 350 straight-pull hubs with Pillar 1420 XTRA spokes. The set weighs an actual 1249g and cost me $550 incl. shipping (I caught it on an AliExpress sale).
    RIDE IMPRESSIONS
    The light weight and efficient power transfer were consistent characteristics regardless of how I built the bike. I was stoked with fast acceleration and was able to lay power down from a comfortable saddle position without any noticeable flex from the bottom bracket area even in the sprints. This is very much in contrast to cheaper BXT and Tideace hardtails I’ve built which were flexy when laying down the watts and also had short reaches and saddle points positioned too far forward on the frame.
    When built up to a SID 100mm fork and rolling on 29x2.25” Schwalbe Rocket Ron tires, the bike had an ultra-efficient XC race character. It was stable and managed every climb comfortably. For most courses that need a hardtail, stability is a good thing. However, in technical sections the long chainstays seemed to make it hard to lift the front wheel, hop, or maneuver sharply. I expect that this is where the FM-199B would shine.
    With a longer-travel Fox Float 32 SC fork, the hardtail was much more playful and confident on the descents. Still, if this were a dedicated 29er setup, I would prefer the 199B.
    TanTan FM-299B Long-Term Review, 18.5lb 00 XC/Trail Build-img_5589-copy.jpg
    I spent a good deal of the winter running the Vee Trax Fatty 27.5x3.25” tires on groomed singletrack when the base was hard. The Trax Fatty did the job, and while I was routinely one of the fastest guys on groomed singletrack, I felt that the tires stuck to the snow, dirt, and mud and felt even more sluggish on pavement.
    TanTan FM-299B Long-Term Review, 18.5lb 00 XC/Trail Build-img_5625.jpg
    I didn’t want to go with narrower tires because I needed every possible bit of flotation. I considered stuffing a 27.5x3.8” tire into the rear but couldn’t be confident it would fit. I’m glad to have tried 27.5+ this winter, but next winter I will be back on 26x4.0 Jumbo Jims for the perfect combination of speed and flotation.
    The press-fit bottom bracket was disappointing, maybe I'm biased because I generally hate PF bottom brackets. I love my Race Face Next cranks, but a 30mm spindle inside a press-fit shell means the bearings are very small. I blew through two sets of bearings this winter and put up with lots of loud creaky noises. I much, much prefer threaded bottom brackets.
    Is this frame for you?
    If you’re looking for a lightweight hardtail carbon frame for your next build or just need a frame to swap over components from an alloy frame, the 199/299B is a great option. This frame is much better than offerings from Tideace, BXT, and cheap eBay, Amazon, and AliExpress products.
    The 299B is your best bet if you’re looking for a hardtail that can also fit wider tires but isn't a full-on fat bike. However, at least in my opinion, it is not a substitute for a fat bike.
    If you’re just planning to run 29x2.4” tires or narrower, I recommend the 199B, the newer Pro-Mance FM015, or the LightCarbon LCM908. The 299B is not ideal for rides demanding long travel but can make a capable pack rig, XC race whip, or trail shredder.
    Pros:
    • Light and stiff construction
    • Versatile geometry and tire options
    • Understated looks and smooth lines, nice raw finish
    Cons:
    • Flat mount rear disc brake, flat-to-post adapter needed (but included if requested)
    • Somewhat long (440mm) chainstays on the 299B
    • Press-fit bottom bracket
    Follow me on Strava, Instagram @therealsissypants, and Facebook
    Feb 2013
    Great review! Cool bikes!
    skidding is the signature of the novice; learn how to use your brakes.
    Sep 2016
    Thanks, I sold off the bike like this:
    TanTan FM-299B Long-Term Review, 18.5lb 00 XC/Trail Build-1.jpg
    I recycled my favorite parts to the LCFS937 build which I just completed tonight. I'll have a first ride review next week.
    Mar 2019
    Do you know how much the pro-mance frame is?
    Sep 2016
    Quote Originally Posted by chrisvwpw View Post
    No, they quote everyone differently. It should be in the ballpark of $400 plus shipping.
    Aug 2015
    Hi Sissy pants, great work and writeup as usual! Any idea if the 199B will fit standard M9000 cranks? Thanks
    Sep 2016
    Quote Originally Posted by ptd006 View Post
    Thanks! It would fit the cranks but you'd need to get a chainring with 3mm outward offset to get the chainline optimized for the boost spacing in the rear.
    Jul 2016
    "Jerry" and "Mint Chip" came in today, they are both tantan 199. Both 199's. I received "Happy Stick" and "Rhino" on friday but didn't take good photos of the latter two.
    "Jerry" will be an upper middle class build, fox 32sc, XT and Carbon rims/carbon cranks 21.5#. "Mint Chip" will be full on boushie class, fox 32 sc, xtr / sram, full carbon 19.8#.
    Happy stick will be 19.8# and Rhino, a tantan 299 will be a 29+ with 3" tires and a pike 100mm fork 23.7#.
    TanTan FM-299B Long-Term Review, 18.5lb 00 XC/Trail Build-4e3ab5d1-863a-48db-98ea-44abc1630714.jpg
    TanTan FM-299B Long-Term Review, 18.5lb 00 XC/Trail Build-img_20190518_155014812-1-.jpg
    Jul 2016
    "Jerry", my 16yo nephew's birthday gift. She's a 19.7# rocket sled. TanTan199
    "Black Rhino" a friends build. Black Rhino is a 23.7 lb brawler TanTan299
    Attached Thumbnails Attached Thumbnails TanTan FM-299B Long-Term Review, 18.5lb 00 XC/Trail Build-ec56b6b5-a3d3-4ac2-a669-3485293c57b6.jpg
    TanTan FM-299B Long-Term Review, 18.5lb 00 XC/Trail Build-img_20190601_192309218.jpg
    Nov 2014
    Quote Originally Posted by sissypants View Post
    In MHO - Flat mount makes not much sense any way. Idea is "oh, we're gonna make thiner more comfortable seatstays under smaller angle".
    However, the problem was already solved by, for example, Scott (2017 Scott Scale RC), simply by mounting rear brake calliper on chainstay and rear axle mounted adapter.
    Also, from the engineering point of view, it makes more sense to put part of the braking forces on a rear axle, which is already very tough. It makes for less stressed frame in general, and gives a better anchor for the calliper itself.
    Mar 2014
    Do you know if they will custom paint these frames? I have purchased two Hongfu frames and they painted them to my spec, which was pretty awesome. I've had great success with Hongfu, and would stick with them, but thought I'd see about comparing some other "brands".
    Jul 2016
    Quote Originally Posted by mtnbikebend View Post
    please see my thread #8, yes they will custom.
    Formerly PaintPeelinPbody
    Reputation: PHeller's Avatar
    Dec 2012
    Anyone else riding these?
    Work - Utility GIS Analyst
    Party - 2019 Guerrilla Gravity Revved Trail Pistol Sz 3
    Jul 2016
    Just finished "big wig" up today. I put this build on hold for a bit for many reasons, but decided the time to finish her up was now. A couple cosmetic loose ends to tie up, but she's 99% done and ready for the maiden trail ride today. 21.3lbs with pedals.
    Attached Thumbnails Attached Thumbnails TanTan FM-299B Long-Term Review, 18.5lb 00 XC/Trail Build-8306a05b-9110-4d53-a363-10ecf256a3f6.jpg
    TanTan FM-299B Long-Term Review, 18.5lb 00 XC/Trail Build-efbaed3d-376a-49e0-94f5-7f2eec2af56d.jpg
    Reputation: Viva Borracho's Avatar
    I am looking to build one of these up for a 27.5+ bike. I prefer the shorter chainstays on the 199. Can the 199 fit a 2.6 Tire (Maxxis Recon) on a 35mm rim?
    I am not planning to ever put a 29+ tire on it?
  1. TanTan FM-299B - A new, ultralight 29+ frame
    By sissypants in forum 26+/27.5+/29+ Plus Bikes
    Last Post: 05-03-2020, 05:50 PM
  2. 21lb FS 29er build (Pro-Mance M9007)
    By sissypants in forum 29er Bikes
    Last Post: 09-08-2019, 09:28 AM
  3. Long LONG term review 2FO's
    By Osco in forum Apparel and Protection
    Last Post: 11-23-2017, 09:56 AM
  4. Damn, that's light! 21lb. Czar
    By mtbnutty in forum Turner
    Last Post: 01-15-2014, 03:29 PM
  5. EVOC FR Trail Long Term Review
    By mudpuppy in forum All Mountain
    Last Post: 02-03-2013, 09:40 AM
Members who have read this thread: 126
