"Tai"-Jones - Page 6- Mtbr.com
Page 6 of 6 FirstFirst ... 23456
Results 1,001 to 1,028 of 1028
Thread: "Tai"-Jones
  1. #1001
    All the years I've been looking at Jones pics, I can't remember ever seeing dirt drop bars on a Jones. Wonder why that is? Because the Loop bars are in a similar ballpark?
  2. #1002
    .44
    Reputation: stremf's Avatar
    Dec 2012
    Quote Originally Posted by Slow Danger View Post
    I suppose the taller riders can pull that off, but the ETT is too long for me for dirt drops.
  3. #1003
    Reputation: D_Man's Avatar
    I've thought about this too since, at 23"', the TT is pretty short for my 6'2" tall frame, but just about spot on for my road bike TT length.
  4. #1004
    Love,peace and baby geese
    Do you hit the front tire with your toes?
    Great spirits have always found violent opposition from mediocrities.
    Albert Einstein
  5. #1005
    Reputation: rcnute's Avatar
    None for me with 10.5 shoes. Plenty of fork rake.
    Ryan
  6. #1006
    Quote Originally Posted by treesmasher View Post
    Occasionally, with the 29+ front, when my size 12 feet aren't sitting properly on my flat pedals. As long as I'm situated properly, no issues.
  7. #1007
    I've fitted some out of curiosity. Felt OK initially on road but added nothing to the bike really, didn't get as far as riding it off-road on anything tricky as 1st impressions were enough to know that it would be lame, bike felt like it had one arm tied behind its back. Loops do a way better job for every aspect of riding apart from road riding into a headwind and there's better bikes for use with drop bars if they're important to you (imo).
  8. #1008
    Powered by ice cream.
    Reputation: Enel's Avatar
    My Tai Jones is still killing it.
    This is why I prefer a very rigid front end that does not tuck under me. The Jones diamond frame with truss fork provides extremely high for-aft rigidity due to traditional diamond shape, long rigid specific head tube and truss fork. It doesn't coddle you, but it doesn't flex much either when you need it to stay solid and predictable.
    Couple freeze frames below.
    I need to ride it more and I need to ride more in general.
  9. #1009
    Reputation: aybee's Avatar
    Feb 2014
    Raced the SF today! No podiums but ton of fun!
  10. #1010
    Reputation: NZPeterG's Avatar
    Hi all Jones Lovers and Owners
    We now have a Jones Thread for all Jones
    http://forums.mtbr.com/custom-builde...s-1006728.html
  11. #1011
    Is anyone interested in selling their Tai Jones?
    I've posted in the Classifieds, but figured I might get lucky here. I also have a few 29+ frames, if you're interested in a trade.
    Enjoy the ride!
  12. #1012
    Reputation: david.p's Avatar
    Into the fourth year with my Jones - I replaced the 120tpi Knard with a 60tpi Dirt Wizard, replaced the rear Ardent 2.4 with a Goma 2.4, and built a new rear wheel using a WTB Asym i29. The Goma does have better climbing grip than the Ardent (even before moving to the wider rim) and the wider rear rim makes the whole bike feel more stable in slow technical terrain. The big change was the Dirt Wizard in the front. It's heavy but gives much more confidence in loose corners and tackles rocky downhills without bouncing as the Knard tended to do.
  13. #1013
    Well at last (almost) finished my new Jones Diamond bike.
    1st ride this afternoon
    Huka Falls, Taupo, New Zealand
    Son28 and Paul brakes
    Pete
    Kiwi Pete from the Singletrack
    Alive so go for a ride
  14. #1014
    Jun 2010
    Kiwi Pete,
    Looking forward to details on your build and how the ride compares with the Jones Plus.
    Dennis
  15. #1015
    My new Jones Diamond set up with a new Shimano XT FD-M8000-H side swing front derailleur worked out great with a few single cable mounts thanks to Jeff Jones for having the two upper bolt mounts ☺
    The Side Swing front derailleur shifts so much better than an old model front derailleur.
  16. #1016
    Jun 2010
    I just ordered a diamond frame with unicrown fork and am starting to order up parts. Can someone tell me what size/number of headset spacers I need?
    Thanks, Dennis
  17. #1017
    Reputation: seat_boy's Avatar
    Standard 1-1/8" spacers, as many as you need to get the bars up where you want them. Best to put a couple of extra above your stem, in case you want to raise your bars later.
    Quote Originally Posted by fyrmd View Post
    Thanks, Dennis
    http://www.bikingtoplay.blogspot.com/
    RIGID, not "ridged" or "ridgid"
    PEDAL, not "peddle." Unless you're selling stuff
  18. #1018
    Jun 2010
    I'm sorry, I wasn't very clear with my question. I will be using a Thompson stem, and need to know the total distance from the headset that I need to fill with spacers, since I don't have the frame yet.
    Thanks again, Dennis
  19. #1019
    It's up to you. The fork comes uncut at (probably) 300mm. Maybe 350mm. If you don't cut the fork, then the number of spacers you need is:
    fork length: 300mm?
    stem clamp height: ~40mm
    headset stack height: ~35mm
    head tube length: not sure
    Add the bottom three numbers up, subtract that from the steerer length, and that's the maximum amount of spacer you will need. Less if you cut the fork.
  20. #1020
    Hi guys, thinking of getting a Spaceframe 29 frameset, was wondering if I could just use my current rear wheel from my El Mariachi. I have a Hope 2 Pro Evo on the rear 135 QR. Will this work? Thanks!
  21. #1021
    Hi Yes.
    The Hope hub can be changed with just axle end caps.
    The Steel Spaceframe is 135mm and will just fit in.
    The new model Ti Spaceframe is 142mm so you will need the 142mm Hope end caps
    Happy riding
    Kiwi Pete out Bikepacking somewhere ☺
  22. #1022
    So the steel spaceframe take QR? Cool, thanks a bunch! Looking forward to getting a Jones
  23. #1023
    Seven going on eight years later the Tai Jones steel frame keeps plugging along.
    It has had a hard life.
    It still delivers loads of fun. I havenít had any bike this long ever.
  24. #1024
    Reputation: Redlands R&C's Avatar
    Dec 2013
    How do you like the ride with the shortish stem and the non-Jones bar? Legitimately curious, I am out of trail shape and when I rode last week on a trail, the loop bars felt a little out of their element. I know most of this is me and my lack of conditioning at the moment, but it did cross my mind to swap my setup
  25. #1025
    Quote Originally Posted by Jason Rides Bikes View Post
    I like it so much I havenít changed it in 6 years.
    Donít care for Jones bars.
    A Jones frame rides just like any other bike, there is no magic sauce to having the bars match the frame and fork (but it does look cool if they match).
  26. #1026
    Dec 2013
    What length stem/width bar are you running?
  27. #1027
    Inspiration to hang onto mine.
    Ryan
  28. #1028
    Reputation: bonesetter2004's Avatar
    Quote Originally Posted by Enel View Post
    Sounds about right - me and my JJ (LWB Plus) are an item, with no intention of going separate ways.
    For the type of riding I do, it's the perfect bike for me, with all-day comfort, capability and fun
    Vive la Jones!
Members who have read this thread: 8
