Stan's, 26" or 29" rimstrip?- Mtbr.com
Results 1 to 19 of 19
    Reputation: VT Mike's Avatar
    I've noticed quite a few people on here mention that they are using Stan's 26" rimstrips on their 29" wheels. Is there some advantage to doing this, or are people just using the rimstrips that they have leftover from their 26" wheeled bikes? Does it depend on which rim you are using - 26" rimstrips work better on some, while 29" rimstrips work better on others?
    elbow gloves
    Reputation: kinkcrazy's Avatar
    I just converted to stans
    with 29er rim strips. Getting them on the rim nicely was kind of a pain on my bontrager Mustangs. The rim strip seemed just a bit long. I started from the stem and had to push the rim strip towards the stem hole as i put in each section. If you stretch the rimstrip away from your starting point you will end up with a big pile-o-rimstrip somewhere in the middle that will never sit down. Once the rim strips were on though, I had the most pleasant experience inflating my fast track tires. Could have easily done it with a floor pump.
    matt
    NoTubes.com
    Quote Originally Posted by VT Mike
    The rim strip used is determined by the rim width and to some extent the depth of the inside cavity. Many of the current rims available for 29" are on the narrow side and the 26" strip will work fine. When I have some time (hopefully very soon) I will get the website updated but in the interim, feel free to contact us through the website or give us a call 607-739-2301 if you are not sure which strip will work best.
    bike geek
    Reputation: tamjam's Avatar
    Quote Originally Posted by kinkcrazy
    matt
    Ditto. Getting the Fast Traks to air up with a floor pump was virtually as easy as if I were using a tube. And it was my first try.
    I'm using 29er strips on Mustangs. It's a tight fit, but patience and a plastic tire lever is all you need to get it to sit tight there under the bead lip. Only one ride on them, but so far so good.
    Quote Originally Posted by Mike B.
    Thanks Mike. Might as well keep the discussion here for the benefit of others. I don't have the wheels yet, but I'm planning to use Velocity VXC rims. Which rimstrip do you suggest for those?
    Reputation: goneskiian's Avatar
    Sep 2004
    Hope you don't mind if I piggyback a recommendation question on here too!
    If you could recommend a strip for the new Salsa Delgado Disc rims that would be awesome!
    Thanks,
    -Ian
    Reputation: chidDONG's Avatar
    Mar 2005
    Quote Originally Posted by goneskiian
    Thanks,
    -Ian
    ditto that. I'm guessin that the 29er strip would be needed for the delgado since its wide but would like some input before buying it. I have some 26" strips laying around so I might try that first for sh*ts and giggles.
    things are more like they are today than they ever were before
    boring blogs:
    racin rick dam nelsons
    links:
    Bikeman
    Salsa Cycles
    SRAM
    Panaracer
    NoTubes.com
    The VXC rims will work best with the 26" rim strip and as always, if you have loose fitting tires, you can add a layer of narrow velox type tape below the rim strip.
    Remember - wire beads only for tubeless 29er conversions.
    NoTubes.com
    Thanks,
    -Ian
    We haven't had one to work with here yet and I don't know what the cross section looks like so based on width alone, the 29er strips are the way to go. We'll always work with you on an exchange if the strips don't work out.
    Aug 2005
    Too bad WTB
    isn't making wire bead 29er tires anymore. Did you catch that thread a couple of days ago? I spoke with them and they gave me the low down. 29er tires will only have aramid beads from here on out. No more steel/wire.
    Who else is making a non-folding 29er tire?
    Jeremy
    Mar 2005
    Quote Originally Posted by OneGearGuy
    Great thread!
    Such useful info so far- esp. considering I have Mustangs and a set of Fast Traks.
    Mike B.
    Thanks for your help here. Do you think it's possible to create a current list of rims/tires that your rimstrips are compatable with and the corresponding rim strip size?
    OGG
    thats actually already on the notubes website. they don't have all options but have a good amount.
    boring blogs:
    links:
    Bikeman
    Salsa Cycles
    SRAM
    Panaracer
    Cold. Blue. Steel.
    Reputation: OneGearGuy's Avatar
    Great thread!
    Mike B.
    OGG
    Spinning and Grinning...
    NoTubes.com
    Quote Originally Posted by chidDONG
    yeah, a lot of the stuff is there already but it is due for a major update - soon I hope.
    Recovering couch patato
    Reputation: Cloxxki's Avatar
    I got inspired. Took a new 355 ZTR wheel and a used dirty Fast Trak. Would air up with the floorpump just like that. Added the 29" strip, and almost immediately I got it to inflate! Keeping air decently already, just loses air too quickly to ride it for a while.
    I wonder what would be a good seating psi that still keeps a bead intact. Or should one just manually seat the tire when at lower, burpble, pressure?
    i heart singletrack
    Reputation: mgersib's Avatar
    I've used 26-inch Stans rim strips on 29-inch rims...
    ... out of convenience, I'm using the 26-inch Stans rimstrips I had laying around on my Dos Niner (with Delgado X rims) -- no problems. Tires air up easily and hold air better than with tubes. the strips themselves stretched to fit the larger rim with seemingly no issues (to-date).
    That said, next time I buy rim strips, I'll get the genuine 29-inch versions.
    Cheers,
    MG
    SUBLIM8er
    Reputation: Axis II's Avatar
    How many are running tubeless w/out rimstrips? I've never used rim strips and seem to do just fine. It's a bit of a pain to air up intially (gotta use the gas station's air compressor) but, after that it's all good. I'm willing to sacrifice some convenience for lower rotational mass.
    Every man has inside himself a parasitic being who is acting not at all to his advantage.
    William S. Burroughs
    which tires are you using if you don't mind me asking??
    SUBLIM8er
    Quote Originally Posted by JC2niner
    In 26- Scwalbe RR, Conti Explorer SS, Conti Gravity pro, Conti Twister SS, Hutch. Python
    In 29- Ignitors
    Works for me
    Reputation: Fisty's Avatar
    Quote Originally Posted by Cloxxki
    When I went to Stan's to have him help me get my tires to work he aired them to max psi during the entire process. This was a few years back but it seemed to work.
