Results 1 to 3 of 3
    Specialized Epic 2015 - Front derailer
    Bike is 2015 comp epic aluminium, current front chainring setup is 2x10 system with 22,40 chainring,with a GXP BB crankset with the front derailer fine tuned I still get a slight rub of the chain against the inside of the derailer when shifting through from the 17 to 11 at the back, if I adjust the barrel adjuster on the shifter I get a total smooth ride with no rubbing of the chain.
    I want to eliminate this adjusting of the barrel adjuster to keep it quite, is there another front derailer I can use instead of the one that came standard with the bike.
    Jul 2017
    If your budget allows, why donít you consider upgrading to 1x11 instead?
    the budget is a bit limited , and I am not strong enough and not very fit so I would like to stick to the 2 chainrings
  1. Replies: 7
    Last Post: 07-11-2014, 07:27 AM
  2. Replies: 2
    Last Post: 07-09-2007, 04:26 PM
  3. need help fixing derailer hanger and tuning rear derailer.
    By norcobryce in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-08-2007, 03:45 PM
  4. Front derailer suggestions for 06 Epic
    By gateCrasher in forum Specialized
    Last Post: 01-16-2007, 05:51 PM
  5. XT derailer or XTR derailer???
    By finchy in forum Downhill - Freeride
    Last Post: 04-05-2004, 04:58 PM
Members who have read this thread: 8
