So I weighed my new SLX crank arms...you'll be surprised.- Mtbr.com
Results 1 to 79 of 79
    Reputation: vizsladog's Avatar
    589 grams
    These are fc660 3 ring 175's with pinch bolts installed.
    175mm XT M 770's from sicklines
    Guess the weight difference is in the rings
    Noli Me Tangere
    Or couple of grams worth of dust on the XT's... lol
    Annie are you ok? Are you ok, Annie?
    I dig trails!
    Reputation: Mr.P's Avatar
    Feb 2005
    Quote Originally Posted by vizsladog
    And bolts. More aluminum for XT.
    Good find!
    P
    Reputation: shiggy's Avatar
    Dec 1998
    589 grams
    It was the same for the last versions of XT and SL cranks. The difference was in the rings.
    mtbtires.com
    I'd like to know what it is with the bottom bracket & triple chainrings. In other words complete. Shimano site states 889 with BB and 44-32-22. But you've probably mounted it by now.
    Half our life is spent trying to find something to do with the time we have rushed through life trying to save
    MTB Rider
    Reputation: willtsmith_nwi's Avatar
    Jan 1970
    Too bad those don't come in 180mm.
    formerly Giantxc
    Reputation: MrXC's Avatar
    Very good to know, thanks!
    Cars Are Evil
    Reputation: Vermont29er's Avatar
    What is this, the weight weenie forum?!?
    Your pic of the SLX's does not show/include the pre-load bolt.
    Good info! I was going to get XT's in favor of SLX's I currently have. Not any mo!
    That is the reason why I buy the SLX cranks over the XT's. That, and I think the SLX cranks look better.
    It would be cool to have a database of component weights on this website
    Reputation: riiz's Avatar
    Quote Originally Posted by S:Drive
    +1
    Glad someone else notices that, the SLX arms always look better.
    Actually im gonna go 1x9 so ill weigh the rings and bolt tonight
    gbnemba.org
    Reputation: Chris_T's Avatar
    Feb 2005
    Quote Originally Posted by esXso
    Now it's on this website :-)
    http://weightweenies.starbike.com/listings.php
    The Vandal strikes again
    So, 5 grams difference. What is the REAL difference between the two cranks? Strength?
    '99 Safari
    Quote Originally Posted by barticus
    SLX crank is stronger.
    Reputation: elgordo's Avatar
    Jan 2005
    589 grams
    I dont see the crank arm fixing bolt in the SLX picture. Is that the 5 gram difference
    Personally I like the looks of the SLX better and since I'm running these SS that would be my choice over the XTs.
    Quote Originally Posted by Dictatorsaurus
    So then...what makes XT more expensive?
    '99 Safari
    ^^ B/c it's labeled XT
    Reputation: boomn's Avatar
    it comes with more expensive rings that do make the complete crankset lighter
    beater
    Reputation: evasive's Avatar
    Feb 2005
    Quote Originally Posted by riiz
    +1
    Agreed.
    Quote Originally Posted by boomn
    Thank you for your answer. Now I feel better about owning an XT crankset.
    '99 Safari
    You can lighten them up even further by drilling about a dozen holes in each arm.
    Chumley for prez!
    Reputation: mr. welcorn's Avatar
    Quote Originally Posted by Dion
    Best Idea I've heard so far! Speed Holes are so underrated and make a cool whistling noise when you ride fast! I'd be shocked if someone on the 29er forum hadn't already tried this
    XTR arm weight
    In case anyone was curious, I just weighed my FC 970 XTR arms, without end bolt, and they were 530 grams. Weight of entire crank w/BB was 796g. I was hoping that the XTR cranks were close to the weight of the SLX so that I could take them back and save the money and use SLX, but now I have to decide if the 55 or so grams is worth the $200 or so dollars difference. I'm using them for a SS.
    Reputation: JSumner13's Avatar
    I run an XT big ring on my SLX cranks. Most of my riding buddies run 2X9 so they give me their big rings
    Attached Thumbnails Attached Thumbnails So I weighed my new SLX crank arms...you'll be surprised.-picture-942.jpg
    Never trust a fart
    Reputation: frdfandc's Avatar
    The double ring with bash SLX is what's toted as being stronger than the XT, not the 3 ring version.
    But I'm in agreement that the SLX looks a ton better than the XT stuff.
    Reputation: WindWithMe's Avatar
    I thought this has been said before. The only difference in weight is in the granny ring (22) which is aluminum on the xt crank,and is steel on the slx crank. I believe its a difference of 33-35 grams...I opted for the slx crank because it looks better.
    Quote Originally Posted by WindWithMe
    The big ring feels significantly heavier on the SLX as well. I've never weighed them but you can actually feel the difference when picking them up.
    yes big ring is also heavier on slx.middle ring is same on both
    drev-il, not Dr. Evil!
    Reputation: Drevil's Avatar
    Quote Originally Posted by mr. welcorn
    A buddy of mine is a machinist and did this while bored at work. It's a Shimano, and he's been riding it this way for the last year:
    No idea how flexy it is, but it doesn't hit the chainstays
    "Keep your burgers lean and your tires fat." -h.d. | ssoft | flickr
    CB2
    CB2 is offline
    Jam Econo
    Reputation: CB2's Avatar
    Quote Originally Posted by Drevil
    Your buddy is a braver man than me!
    Reputation: A1an's Avatar
    Great info . Think I may grab a set of these.
    Signature
    San Diego County
    Reputation: Duzitall's Avatar
    Those are Isis and pre-hollowtech? I always thought my 770's were actually hollow. They sound hollow.
    Quote Originally Posted by turnerbikes View Post
    Of course the easiest way to fix this is to go for a hike.
    DT
    Keep on Rockin...
    Reputation: Miker J's Avatar
    Nov 2003
    They need to drop the 170s and make 180s.
    Reputation: htfu_aaron's Avatar
    Aug 2010
    <a href="https://www.flickr.com/photos/[email protected]/5374120142/" title="IMAG0141 by htfu_aaron, on Flickr"><img src="https://farm6.static.flickr.com/5045/5374120142_843f3f1575_z.jpg" width="383" height="640" alt="IMAG0141" /></a>
    Not surprising.
    http://htfuaaron.blogspot.com
    2012 Niner Air 9 SS
    2011 Crux
    2012 Crux SS
    This is very interesting news indeed. I went through a WW planning phase but in the end I decided to purchase an entire bike's worth of mid-grade parts, rather than have 1/4 of a really nice bike put together. I'm glad I went with the SLX cranks!
    transmitter~receiver
    Reputation: meltingfeather's Avatar
    Quote Originally Posted by Duzitall
    Not to nitpick, but Shimano never made an ISIS crankset. You probably mean Octalink.
    Anyway, I think the SLX cranks are pretty damn sexy myself.
    I'm thinking about a set for my ss and would go w/them over XT on looks alone.
    XTR on the other hand...
    Quote Originally Posted by pvd
    Time to stop believing the hype and start doing some science.
    29er Tire Weight Database
    Aug 2010
    Quote Originally Posted by meltingfeather
    +1
    Damn my bike for being spec'd with reasonably light but ugly crankarms!
    2012 Niner Air 9 SS
    2011 Crux
    2012 Crux SS
    get down!
    Reputation: appleSSeed's Avatar
    Quote Originally Posted by willtsmith_nwi
    Ditto. This is the reason I went with XTs. I had some hollowtech Deores back in the day and it was the same story...just as light as the nicer stuff. Rings + hardware is where the difference is.
    Rudy Projects look ridiculous
    visit my blog, BEATS, BIKES & LIFE
    Broke college student
    Dec 2009
    I love when pricing doesn't necessarily translate to performance! Got my SLX cranks that were taken off a new bike and sold as "used" for $75 on eBay. Best investment Iv'e made yet on my bike!
    I like beer.
    Reputation: OmaHaq's Avatar
    Jun 2010
    Not suprising at all about the SLX's. I use a set of Shimano XTR M952's (circa 2001) w/ a spiderless ring. The BB was around 255gr and the arms were around 400gr.
    A lot of times, the older stuff, and the cheaper stuff isn't that much heavier.
    Compare a Sette APX seatpost to a Thompson. Both are milled, one piece. APX is lighter and 4x cheaper and the wall thickness is darn close to being tghe same.
    I dig trails!
    Feb 2005
    Quote Originally Posted by OmaHaq
    Not both 1 piece. Wall thickness is radically different. APX = 2014 Thomson = 7005 ovalized aluminum.
    APX flexy noodle. Thomson sturdy, trusted friend.
    Now back to the cranks in the discussion.
    P
    Quote Originally Posted by Mr.P
    P
    I bet fat chicks are your sturdy, trusted friends too
    Missouri sucks...
    Question about SLX cranks...
    I plan to run 1x9 with a BB mount chainguide. Has anyone done this? Will I have to machine down the granny bolt mounting holes or should it work with no mods?
    Quote Originally Posted by DFYFZX
    not with SLX, but I have run such a guide with other Shimano external BB cranks. No mods needed, nor have I heard of mods being needed
    Missouri sucks...
    Shwing!
    I'm running 1x10 with the MRP 1.x and it works perfect!
    adam michigan karate monkey
    Aug 2010
    @ADDam Was the MRP a pain to set up? Were you able to keep the chain from rubbing at the top and bottom of the cassette?
    2012 Niner Air 9 SS
    2011 Crux
    2012 Crux SS
    Missouri sucks...
    I've used the MRP before and it's not hard at all. You, of course, have to take out the drive side BB cup but other than that "tedious" step is easy as pie to set up Takes MAYBE 15 minutes if you're mechanically competent and then you never have to fiddle with it again. Set and forget
    1*14*29*2.1 & 1*1*29*2.4
    just weighed mine...got 596g wo rings, and 682 with bearings(wo rings)
    *checks this is the 29er forum*
    WHO CARES? 5g? Even the most anti-mud-riding weight weenie will pick up that much dust on a reasonable ride! I post here for my interest in 29er bikes - I don't go near weightweenies because their pasty skin and obsessive stares scare me.
    Aug 2010
    The point is that it's not worth the price difference you might pay for XT over SLX if you're going to be using a single front ring because the weight difference for the total cranksets is in the rings. Not "OH YEAH! Buy SLX because they're 5g lighter"
    2012 Niner Air 9 SS
    2011 Crux
    2012 Crux SS
    Quote Originally Posted by htfu_aaron
    No not really, The PITA comes if you dont get it perfectly level and reinstall everything. I had my bike in my stand when I was doing it and when I put the crank back on I realized that it wasn't level. So my best advice would be to set the bike on the ground when tightening the BB cup make sure the "MRP" logo is parallel with the ground.
    Hope that helps! Adam
    Aug 2010
    Quote Originally Posted by ADDam
    I'm more asking in general; I know it's kind of apples to oranges but my Stumpy has a pressfit bottom bracket so I have a e*thirteen XCX on the seat tube. I had a really hard time getting it set to not rub the "cage" in my biggest cog but never had any problems with rub in my smallest cog. I even tried a 10spd chain with no luck. I debated between the e*thirteen and MRP products so I was just curious; trying not to kick myself for picking the "wrong" one for my bike's nuances ;-)
    2012 Niner Air 9 SS
    2011 Crux
    2012 Crux SS
    exactly......
    So the SLX cranks are stronger, lighter, cheaper, and they look better than the XTs. They kind of legitimize the whole SLX line and have to be one of the best value components out there.
    Reputation: Ronnie's Avatar
    Quote Originally Posted by frontierwolf
    I fully agree with you that the SLX groupset is as good as XT, the only difference is that XT is a little bit lighter. "Looks better" is a matter of opinion. However the assertion that the SLX cranks are stronger comes from the claim by Shimano that the SLX M665 two ring 22/36T all mountain crankset is stronger, which it is. I've had a set. They have a steel insert for the pedal threads and are reinforced by the bash guard. They are not the same cranks as the M660. They are also a lot heavier.
    Ronnie.
    The trouble with having an open mind is that people will insist on trying to put things in it.
    Did I catch a niner+?
    I have the XT set on my SS my rommate has the SLX set on his 3x9 and I also have the LX set.
    I got the XT set when Nashbar was blowing them out and I got to use a coupon on top of it, I like the look of the setup much more in a brush aluminum. However if weight is not an option (which most agree here) I would say the LX is a much better buy unless you get the SLX at the $99. The cranks are without a doubt heavier then my XT set but at ~$79 they're hard to beat. Since I run my XT SS I swapped the rings out and put them on the LX set, this does help with weight especially on the small ring which is steel on the LX set. I think a lot of SS'ers go for the XT due to having a 180mm crank option (that was one of my reasons).
    And as Ronnie pointed out it's the all mountain set that is stronger (M665), the notion of the M660 rumors of being stronger has been running all over this forum and simply is not true. Since the M660 is not as strong I am sure that has to do with why it is slightly lighter.
    Reputation: illini's Avatar
    Dec 2009
    I just got a used set, one thing I noticed was torx bolts are steel or a heavy alloy. I held all of those bolts in my hand and damn that's a lot of weight then chucked them in the trash. Did anyone have any problems with stuck torx bolts. Shimano has all but stopped using Allen bolts.
    It's carbon dontcha know.
    Reputation: 6thElement's Avatar
    I don't understand this new fascination with torx for crankbolts either, particularly as most multi-tools only have T25 and the crank ones are bigger.
    Just about every Torx that I have used will fit an allen key into it. The bolts on my XT's allow me to use an allen key without fear of stripping.
    Homemade Jones xtr m960 conversion = 510g
    Bought off ebay for less than an SLX chainset.
    Dec 2009
    The brakes on my chevy truck which use to be allen are now torx. They either have to be cut off or vice grip on the shaft long story. I did find that once you woller one out, drill out the excess and it becomes enough of an allen to get it off. Sorry as you can tell i have an extreme hatred toward the torx.
  67. #67
    Quote Originally Posted by 6thElement
    Torx can handle torque better without stripping. While that wasn't a problem in the first place with steel chainring bolts, it can be a problem with the aluminum bolts that all the manufacturers want to use to make their cranks lighter. New multi-tool designs will adapt as needed, just like how they never had T25 Torx until they became necessary for disc rotor bolts
  68. #68
    Missouri sucks...
    I know I'm pullin mine out ASAP and hitting up TrueValue for some stainless allen head bolts as soon as I get the cranks in hand
  69. #69
    Reputation: Straz85's Avatar
    Anybody weighed a set of M542 cranks? If not, I'll pull them off my bike and weigh them. I'm curious if they're much heavier than SLX cranks, if they are, I may be making a purchase.
  70. #70
    Aug 2010
    Quote Originally Posted by Futon River Crossing
    Tell me about these.
    2012 Niner Air 9 SS
    2011 Crux
    2012 Crux SS
  71. #71
    Missouri sucks...
    Those are modifed XTR cranks. The big ring bolt holes are ground off and then they're polished. Quite nice if you ask me I would like a set someday but I don't currently have a bike that would look right with a set. There is a set for sale in the Classifieds
  72. #72
    Aug 2005
    What chainring is that?
  73. #73
    Hassan's Ghost
    For what it's worth, my FC-M665, the reinforced version of the SLX, weigh 630gr. without rings. Not all that much heavier.
  74. #74
    Jun 2005
    Quote Originally Posted by Straz85
    Dunno about that, but (though I never verified it) I was always told LX & XT weight was comparable w/ out rings. Personally, I have been running Hone cranks w/ different rings/ bolts for years. They have a thicker spindle than the LX and are still fairly light.
    I keep my eye out on e-bay for Hones all the time...I like'em.
  75. #75
    Quote Originally Posted by ChipV
    LX, Hone, SLX and XT all have hollow crank arms using the same technology, however the M542 Deore arms are solid aluminum with some relief areas machined out on the back side. They are definitely heavier, though I don't know by how much
  76. #76
    nothing to see here
    Reputation: Stevob's Avatar
    Quote Originally Posted by The Avenger
    My guess is Middleburn.
    edit...yep
    I see hills.
    I want to climb them.
  77. #77
    I will add these to the mix.
    New Truvativ AKA all mountain hollow forged arms 175mm
    Less money than SLX's
  78. #78
    I dig trails!
    Feb 2005
    Quote Originally Posted by Quadzilla81
    Another great find! This thread delivers!
    The AKAs are made with AL-7050-TV aluminum as well (for the win for me)
    P
  79. #79
    Guess that means I'm taking my cranks off this weekend.
Members who have read this thread: 4
