should a 34T one up oval fit on a ripmo v1- Mtbr.com
Results 1 to 2 of 2
    Im using a 1x11 shimano m8000 bottom bracket. There are no spacers that I can recall between the cups and the frame. The 34T one up scrapes the seat stay. I put in like 2 or 3mm of spacers between the crank and the cups and that allowed the chainring to clear the seat stay. I think this has made it so I cant shift to the 46T cog.
    Would spacers mess up the chainline enough to block shifting to the big cog? I can get it to shift to the big cog on the stand, but it is rough with a cross chain style noise. When I ride it just stays on the 37T
    Should the one up 34T fit? Do I have something setup wrong? I ordered a 30T oval so I can remove the spacers.
    Reputation: MSU Alum's Avatar
    Have you tried adjusting the limit screw on the rear D?
    I thought the V1 was limited to 32 (or maybe 34). A 34 oval will be 36 at its widest.
    My son runs a 30t Oval on his V1 with a 1x12 and it's a little tight. The 34 is quite large, so I'm sure you'd have to do something funky to make it work. Are you using a -3 or -6 degree one up?
  1. Ripmo V1 or Ripmo AF?
    By tl858 in forum Ibis
    Last Post: 03-06-2020, 08:41 PM
  2. Replies: 4
    Last Post: 01-02-2019, 02:46 PM
  3. Sunrace 11-34t vs. Shimano 13-34t 7 speed cassette
    By duckie.nv in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-15-2016, 12:01 AM
  4. Replies: 6
    Last Post: 02-08-2015, 12:46 PM
  5. AbsoluteBlack 32 or 34T 104BCD Oval Chainrings
    By jp08865 in forum Where are the Best Deals?
    Last Post: 11-23-2014, 02:43 PM
Members who have read this thread: 15
