Results 1 to 13 of 13
    Sep 2017
    SC Hightower 29 er with Wide tires
    Anybody running wider tires on their 29er Hightower? 2.5 or 2.6.
    Reputation: unrealityshow's Avatar
    Oct 2017
    Iíve got a Vittoria Morsa 2.3 on a 25 id rim and thatís all the bigger Iíd want to go. I really doubt thereís enough room for a 2.5 or 2.6.
    SS Pusher Man
    Reputation: mtnbikej's Avatar
    Sep 2001
    2.6 won't fit.
    Bicycles donít have motors or batteries.
    Ebikes are not bicycles
    Aug 2005
    It's a tight rear triangle for 29 inch tires. I'd stick with 2.35s and not go much wider than 30 mm rims.
    Vermonter - bikes, beers and skis.
    Reputation: David R's Avatar
    Is the LT any better?
    Reputation: SDMTB'er's Avatar
    Feb 2014
    Quote Originally Posted by Mikeyff View Post
    I have successfully run Maxxis Minion DHF and Aggressor tires at 2.5. Only reason I am not at the moment is DHF is over 1,000 grams.
    Reputation: minimusprime's Avatar
    I run 2.5 DHF on the front and 2.3 aggressor on the rear on my hightower. I also have run a 2.4 DHR on the back but clearance is tight. I don't see much of a need to run a bigger tire in back. The extra .1" isn't going to add considerable grip or tire volume... besides, I like my bikes a bit under tire-ed in the back for the drifting action.
    I'm currently on a SC Hightower 27.5+ with 2.8 tires.... thinking about switching to a 29er... why would 2.5 or 2.6 tires not fit on a bike already running 2.8's? I'm not a pro so looking for some info here. Thanks!
    2007 Trek Fuel EX9
    2017 Santa Cruz Hightower C 27.5
    WLB
    WLB is offline
    Slow but not stopped
    Reputation: WLB's Avatar
    I guess it depends on which tire. I run Nobby Nics 2.6 front & rear on my Hightower, WR1 30mm internal rims, absolutely no problem
    Feb 2014
    Quote Originally Posted by WLB View Post
    Also used these with same internal width with no problem. Maybe muddy conditions may be right but for hardpack no problem.
    Hi, for the guys above with 29x2.6 nics, can you post a pic of the tire fitted? Just wanted to see the clearance. My DHR II 29x2.3 is already a little tight as it is (compared to an older sb95c frame i replaced the HT with.
    Thanks in advance!
    JT
    Sep 2018
    Sounds like it also depends on what rims you are running. I have a 2.35 Nobby Nic (Addix / Snakeskin version) mounted in the rear on i29 rims and there isn't much clearance. I'm really surprised to hear that the 2.6 Nobby Nic fits. The 2.35 Nobby Nic measures a little more than 2.4 inches in width, but it is a tall tire. I don't know if the 2.6 Nobby Nic has a different profile.
    A friend is running a 29x2.6 Maxxis Rekon on the back of his and it is also tight. He definitely has rub marks inside his frame where things trapped in the tire have scraped the frame up.
    Edit: just checked tonight - looks like I have 7-8mm of clearance with my 29x2.35 Nobby Nic in the rear triangle.
    Sep 2018
    Quote Originally Posted by Mike2009 View Post
    The 27.5 tires have a smaller radius, so there is more clearance inherently in the rear triangle. The problem isn't the width of the tire - it's how 'tall' it is (i.e. - how much it increases the radius of the wheel).
  1. Replies: 2
    Last Post: 03-13-2018, 12:22 PM
  2. New Hightower LT vs Hightower
    By arandal in forum Santa Cruz
    Last Post: 01-12-2018, 04:55 AM
  3. 2018 Santa Cruz Hightower or Hightower LT
    By 5k bike 50cent legs in forum California - Norcal
    Last Post: 08-14-2017, 10:27 PM
  4. Hightower Plus vs Bronson with wide tires
    By cmrocks in forum Santa Cruz
    Last Post: 10-07-2016, 09:23 AM
  5. Recommend some wide tires for 33mm wide 26er wheels?
    By exploder in forum Wheels and Tires
    Last Post: 08-09-2014, 12:30 PM
Members who have read this thread: 73
