rising rate/ falling rate?- Mtbr.com
Results 1 to 2 of 2
    Does Shimano even make that line any more?
    I'm asking because I'm building up a frame and am stuck without a local supplier so I need compatible parts.
    Thanks in advance
    \Copied from drivetrain forum
    poser Administrator
    Reputation: rockcrusher's Avatar
    Aug 2003
    Rapidrise (high normal) vs Low normal?
    I think they are strictly low normal now, that is the derailleur defaults to the smallest cog when tension is released. They used high normal for the dual control levers which have also been discontinued.
    I would be looking for old stock of High Normal or just get the low normal stuff and reset your brain to push to easier gears vs. push to harder gears.
    MTBR Posting Guidelines
    calories>electrons
