Rim fixable?- Mtbr.com
Results 1 to 7 of 7
Thread: Rim fixable?
    Aug 2019
    Rim fixable?
    Hey guys. Riding my new bike I noticed that the rim was bent near the valve stem. Looks like a rock hit it or something. Rim fixable?-20190902_192402.jpgThey are DTSWISS M1900 30mm rims. I just put new Stans sealant in it and it seems to be holding air now after a quick ride, but do you think this will be an issue? Should i try to bend it back?
    Reputation: J.B. Weld's Avatar
    Shouldn't be an issue, mine look a lot worse. I probably wouldn't mess with it, sometimes when you bend aluminum back it just weakens it more.
    It looks like a rim strike, I don't know what you were running but you might want to up your psi some.
    I brake for stinkbugs
    Dark Meat
    Guest
    Looks fine...just ride it
    since 4/10/2009
    Reputation: Harold's Avatar
    Quote Originally Posted by J.B. Weld View Post
    Last time I messed with something like this, the rim cracked around the circumference of the rim. Mine was way worse, but it wasn't cracked until I started trying to bend it back.
    Another option would be to install tire inserts. tons of these on the market ranging from lightweight huck norris to cushcore which can handle a ton of abuse. I have huck norris in the rear rim of my hardtail and it's definitely doing its job.
    Reputation: mfa81's Avatar
    If itís holding air there is no reason to mess with it!
    Jan 2019
    It won't be an issue. Long as it's true and holding air, and no through-rim cracks, you are good!
    -Ray
    Reputation: Lone Rager's Avatar
    Dec 2013
    Yep. Looks rideable to me too. I've sometimes straightened out a rim dinged like that, but only when it was worse than what yours looks like.
    What, me worry?
  1. Fixable or Not Fixable?
    By enjoybikes in forum Shocks and Suspension
    Last Post: 04-15-2014, 01:55 AM
  2. Niner Air 9 Carbon BB problem. Fixable?
    By Svend P in forum 29er Bikes
    Last Post: 06-28-2011, 10:27 AM
  3. Fixable Monolink?
    By ssorgs in forum Maverick
    Last Post: 05-10-2011, 07:58 AM
  4. bent rim channel - fixable?
    By wushudrew in forum Wheels and Tires
    Last Post: 07-17-2007, 07:36 PM
  5. bent rim fixable?
    By eman2 in forum Wheels and Tires
    Last Post: 04-22-2006, 12:36 PM
