• 01-28-2005
    endure26
    Reba 29er Travel Adjustment - FYI
    From the SpeedGoat website:
    For all you asking about changing the travel in your 29er Reba fork, here's where to go on RockShox.com:
    http://www.sram.com/_media/pdf/rocks...eamService.pdf
    Page 11 has the travel adjust stuff, but here's the important part: THE PICTURES THERE ARE FOR A 26" REBA, NOT A 29".
    For a 29er at 100mm, you will have NO black spacers on there. When set to 100mm, your 29er Reba will look like their "115mm travel (0 spacers)" picture on the far right.
    For a 29er at 80mm, you're only putting in one spacer between the white piston-thing and the black top-out thing, so when set to 80mm, yours will look like their "110mm travel (1 spacer)" middle picture.
    Enjoy.
  • 01-29-2005
    Swami Scott
    Do you think there could be a way to add a different spacer and make the travel 90mm? Maybe someone's looking for something in between 80 and 100 for geometry tuning or?
  • 01-29-2005
    n8ofire
    cut the spacer in half
    With a hack saw, bench clamp and cutting guide you should be able to hack that all travel spacer in half, I cant think of any reason why that wouldn't work. Actually, the REBA is 85mm NOT 80, so if you cut in half exactly you would get 92.5mm travel
