QTOUR (Agogo) Trail 29er Frame- Mtbr.com
Results 1 to 16 of 16
    Reputation: sissypants's Avatar
    Sep 2016
    This is the frame:
    This was the unlikely source that broke the news:
    https://www.pinkbike.com/news/5-surp...show-2018.html (wrong travel is advertised)
    And this is the geometry:
    This frame is really progressive by Chinese standards:
    • Split seat tube hides shock linkage
    • Huge reach and slack head tube angle
    • Shock mount is exceptionally low thanks to cup (with drainage channel) in downtube
    • 130mm travel front and rear
    • Prominent seat tube/top tube triangle reduces chance of damage
    • BSA73 threaded bottom bracket, unusual when most companies prefer non-threaded BBs (I'll take it)
    • Built-in chainguide mount
    • Constructed from Tenax UTS50, a slightly stiffer carbon filament yarn (compared to Toray 700)
    • 5-year manufacturer warranty
    In my opinion, this is the first catalog frame that really is long, low, and slack. I'm posting here because I'm really impressed by this frame and would love to see it reviewed.
    I was told by Damon Wang at Qtour that "The M06 frame is designed and produced by our company." Indeed, Agogo appears to be a subsidiary brand of Qtour. See Qtour's Alibaba ad:
    https://www.alibaba.com/product-deta...613517982.html
    I haven't yet seen this frame stocked by other vendors or sold on Aliexpress.
    Based on the severe lack of aftermarket visibility, it's possible that Qtour will focus almost exclusively on OEM service. After informing them I only needed a few frames, I was met with silence (unusual).
    Travel is not 100mm as indicated in the PB article, it is 130mm front and rear. Specifically, an A2C fork length of 541mm corresponds to a Fox 34 with 130mm travel. A 165mm shock (eye-to-eye) in the rear is what normally gets specified on XC bikes, but the frame is designed around 130mm rear wheel travel.
    Maybe this could be converted to an XC machine with a Fox 32, but cutting 40mm of fork length would increase the HTA by ~2 degrees (from 67 to 69) making an angleset worth considering. Also, there is no solution I'd like for reducing rear travel.
    I spent all my bike money. Someone else will have to try this frame.
    You can find the same frame on lightcarbon :
    https://www.lightcarbon.com/new-full...2019_p118.html
    As you can see geometry chart is different from your link : longer reach despite a higher fork (should be the opposite in fact) and stack seems to be more in the norm than the value on qtour chart (for instance 56,6 cm stack on a medium size long travel 29er is not possible)
    Sep 2016
    Quote Originally Posted by chti ludo View Post
    Thanks for pointing that out. It looks to me like lightcarbon.com is simply a reseller.
    I have now tried to reach out to Damon Wang at QTOUR via Alibaba and directly through the factory form. Only 17.5" is available, and he has not expressed interest in a one-off sale. Doesn't leave me with the impression he wants to sell to me unless I can buy a few. Or maybe they just aren't ready to sell yet? No clue.
    May 2005
    130mm travel out of pivotless seatstays...I don't think I like the rear caliper becoming a stressed member of the rear suspension.
    You must ride where it's always dry. Nothing about that frame looks good to me when it comes to mud.
    Ripley LS v3
    OG Ripley v2 handed down to son
    Oh no, just look at those ginormous drain holes
    Is this not an advertisement? Sure looks like one to me.
    Quote Originally Posted by TwoTone View Post
    GG Megatrail 27.5 (Braaap!)
    GG Trail Pistola 27+/29 (speedy)
    Pivot Shuttle 27.5 (wife's)
    Quote Originally Posted by Nurse Ben View Post
    I haven't looked at the OP post history, assumed since OP has been around a few years and few hundred posts that it was blant vendor spam.
    Ripley LS v3
    Sep 2016
    I am not affiliated with QTOUR. No, I am not advertising. I have nothing to lose or gain. It simply struck me as a frame with a substantial amount of creative design for being a catalog frame.
    I am increasingly less impressed with the frame and will not be buying one.
    Sometimes info is hard to find on the internet, so making an obscure catalog frame a bit easier to learn about and discuss isn't a bad thing.
    I guarantee some brand will be slapping their sticker on here sooner or later.
    Sep 2016
    Quote Originally Posted by VegasSingleSpeed View Post
    You mean the seat stay mount? This is pretty common on a lot of trail bikes. It's just a little higher away from dirt and grime. If the rear triangle really moves as a rigid unit through the full stroke braking shouldn't be stressed any more on a seatstay than a chainstay.
    May 2005
    Quote Originally Posted by sissypants View Post
    The rear suspension is a single pivot design. Because it uses a link to couple the shock to the seat-stays, the seat-stays have to articulate throughout the travel of the rear suspension. Most manufacturers address this by adding a pivot near the rear drop-outs where the seat-stays meet the chain-stays. Recently, more companies have been manufacturing the rear triangle in a pivotless design where the seat-stays flex to provided the needed articulation (i.e. Cannondale Scalpel, Kona Hei Hei, etc). These frames typically have less rear travel, and the seat-stays are more slender to provide that flex...they also utilize a rear brake mount that minimizes any flex occurring between the posts of the mount.
    130mm is a lot of travel for a pivotless design, and that brake mount would appear to straddle where I would expect the seat-stays to flex during it's movement through the travel.
    Good luck!
    Jun 2014
    Heres a company rebranding that frame in the US
    https://www.instagram.com/greysbikeco/
    Jan 2015
    Lol it doesn't pivot in one spot like traditional pivot would. It is more like you holding a tree branch and me pulling down on one end the entire branch flex.
    Jan 2015
    Good luck!
    Kona does a 140mm hei hei just saying..also flex stay is my favorite suspension design. Very active and carries speed well so happy to see a 130mm version.
    In addition I think the fact that it is still using only 45mm stroke means they don't flex much more the a 100-120mm would.
    P s. The entire stay flexs. If it flexed at one point that would be very bad.
    I live to bike
    Reputation: Jwiffle's Avatar
    I don't see where either the seat stays or chain stays should need to flex. There's a lower pivot near the bb. There also appears to be a small rocker at the top. No flex necessary.
    Stop in at Element Sports. www.elementsport.com
    Get Out! Have Fun!
    Aug 2019
    Quote Originally Posted by Jwiffle View Post
    If the entire chainstay and seatstay triangle stayed entirely rigid, the arc described between the BB pivot and seatstay pivot, would not match the arc that is described between the upper frame pivot and the seatstay pivot. Without a pivot by the back wheel, the two sections need to flex to some degree so that they can move in unison around those pivot points. Because the upper linkage inside the split seat tube is pretty small, the amount of flex needed in the rear triangle is not huge, but it does not remain entirely rigid.
    Yeaj, this is a very interesting frame, but as a clyde I want some sort of pivot in rear. I just don't trust solid rear traiangles, unless it's a dw link or similar.
  1. Replies: 32
    Last Post: 08-01-2017, 01:34 AM
  2. Replies: 0
    Last Post: 08-25-2013, 09:37 AM
  3. Replies: 3
    Last Post: 10-20-2011, 05:33 PM
  4. Replies: 0
    Last Post: 11-26-2007, 03:21 PM
Members who have read this thread: 4
