Niner Air 9 Build- Mtbr.com
Results 1 to 26 of 26
    Niner Air 9 Build
    Any input on build? Just want to know what people think about the bike.
    Niner Air 9 Build:
    Parts List
    * BK9610 - DreamCycle Mountain XC Disc Bike Build
    * FM1132 - NINER Air 9 frame for DreamCycle
    * ST0920 - Problem Solvers 35.0mm Seatpost Clamp Silver
    * FK0463C - 2009 Fox F29 100RLC 100mm Fork Blk/Wht
    * CR6181 - Shimano SLX M660 175mm Crankset 22-32-44t with Bottom Brackets
    * RD4633 - SRAM 2010 X.9 Rear Long Cage Derailleur Silver
    * FD4606 - SRAM X.7 Front Dual-pull Front Derailleur, LoClamp 31.8/34.9 Black
    * FW6153 - SRAM PG-970 11-34 9-Speed Cassette
    * CH1083 - SRAM PC-971 9-Speed Silver/Gray Chain with Powerlink
    * BR2270 - Avid Elixir 5 Front Disc 160mm Rotor White with Silver Lever Blade
    * BR2271 - Avid Elixir 5 Rear Disc 160mm Rotor White with Silver Lever Blade
    * LD4600 - SRAM X.9 9-Speed Trigger Shifter Set
    * WE2918 - Handspun Front 700c Deore XT Disc M756 Black 32h, WTB LaserDisc Trail Black, 2.0-1.8db Black, Br, 3x
    * WE2919 - Handspun Rear 700c Deore XT Disc M756 Black 32h, WTB LaserDisc Trail Black, 2.0-1.8db Black, Br, 3x
    * HD2234 - Cane Creek S-1 1-1/8" Black Threadless Headset
    * ST7536 - Thomson 31.6 x 410mm Setback Black
    * HB3204 - Ritchey Comp 5degree Flat Bar 31.8mm 580mm Black
    * HT3211 - Ritchey TG6 Dual Density Grips Black/Gray
    * SM4822 - Ritchey Comp 31.8mm 110mm 84/96d Black Stem
    * SA1539 - WTB Speed V Comp Black Saddle Steel Rail
    * TR9382 - Continental Mountain King 29x 2.2" Black Folding
    * TU6896 - Q-Tubes 29" x 1.9-2.3" 32mm PV tube 220g
    What It Be ?
    Reputation: ChrisJ's Avatar
    Aug 2005
    Didn't we go over this yesterday?
    Addicted to Dirt
    Reputation: ingluis's Avatar
    Dec 2004
    Let's play "find what I changed..."
    I deleted this yesterday by mistake nothing has changed, It was only up for a few hours before I deleted by mistake.
    Reputation: jjmtb1's Avatar
    Oh, well in that case, have you thought about better wheels?
    Reputation: Bondseye's Avatar
    get better wheeeeeeeeels
    Nov 2006
    Besides the wheels. heavy cassette and saddle (but both functional though).
    Addicted to Dirt
    Dec 2004
    Wheels...
    get an EMD and spend the extra cash on the nicer wheels and get a bar with some sweep and width
    No i forget what everyone said about the wheeles,crank and there was sonething else to but i for get. Iike i said i deleted the post by mistake.
    What type of wheeles should i go with?
    The best ones you can afford.
    Reputation: OrbeaAbsalon's Avatar
    The mountain kings are nice tires but they are under sized, the 2.2 is more like 1.9 and the 2.4 is more like a 2.2.
    bike rider
    Reputation: mattkock's Avatar
    Ditto!
    What he said. The best ones you can afford. I'm going with Stans Race 29er Single Speed wheels for my Air 9 Carbon build. June can't get here fast enough. My complete wheels with tubes, tires, rotors, rotor bolts and skewers came in at Front=1157g and Rear=1324g. It's going to be SICK!
    My Bikes Kick Ass!!!
    Quote Originally Posted by Bondseye
    Can you suggest several great wheel sets for a 29er. Thanks.
    bt
    bt is offline
    Nov 2007
    round ones
    I dont know if this changes anything my weight is 230.I told the shop that I wanted a good strong wheel not so much light but something that will handle my weight coming down on them. What other brands are out there?
    No longer 26
    Reputation: G-Live's Avatar
    Changes I'd make not already stated
    SLX 22/36 crankset, (very little need for any gear combo bigger than 36/11 imo) combined with..
    MED cage X.9 rear der
    SLX Front der (nice and compact)
    Ritchey PRO stem/post/bars (ideally they should all match )
    X.9 Twist Shifters
    G
    You can't depend on honest answers from dependant hands...
    Reputation: Johnny Chicken Bones's Avatar
    Skip the mountain kings.
    The Mtn King feels terrible. Rolls slow too! Squirmy and not sure footed.
    --------- __o
    ------- _`\<,_
    Running is for prey.
    What It Be ?
    Aug 2005
    I'm building up some Kings laced to Archs. You should do the same.
    Quote Originally Posted by Hard Rain
    I'm currently running Stan's Arch with Stan's brand ZTR hubs. Great wheels, great price, and ghetto tubeless! I previously owned Chris King hubs laced to Stan's 355 built by Dave @ Dream wheels. More expensive, but nice hubs. The 355's seem to be prone to dings if you ride in rocky areas.
    Reputation: DavidR1's Avatar
    Sram 990 or XT cassette.
    Flow's laced to the best hub you can afford (Hope pro 2 seems to be common and solid)
    M_S
    M_S is offline
    Nov 2007
    Nothing wrong with any of the parts that are on there. All mid range to upper mid range. Not light but functional. Not sure about those tires, but that's a preference thing I suppose.
    I kind of agree that you could get some nicer parts with an EMD build instead of the AIR, but if you really want the AIR frame and plan on upgrading a bit later this would be a good way to get into it.
    Reputation: Tinshield's Avatar
    No pics?
    Reputation: gjenkins@'s Avatar
    Quote Originally Posted by Tinshield
    No pics?
    Vapor Wair 9
    R.I.P. DogFriend
    Reputation: jeffj's Avatar
    I don't know about the terrain where you live, but I agree about the comment suggesting the 22-36 crankset. I'm running that chainring combo (on an XT crankset) with a 12-36 cassette and have found no need for for anything more on the top end. It can motor up to mid 20's mph. I find little (or no) need to pedal any faster. YMMV.
