Need input to my winterbike setup (3500USD budget)
Hi MTBR
I really want a second (29'er) bike in my garage to spare my race bike from getting too trashed over the winter and practice.
I want my new bike to perform superbly in mud so I'm thinking fully rigid and 1x9 or 1x10 (this is where I need help)?
This is what I have in mind so far:
Tires, Schwalbe Nobby Nic
Fork, Niner carbon
Stem, Ritchey WCS 110mm
Brakes, Formula RX + NewUltimate discs
Rear derailleur, ????
Chain, ????
Chaingaurd, Superstar XCR
Cassette, ????
Chainset, KCNC XC1 K-Type with a 34 or 36T
Shifter, ????
Grips, SRAM rubber
Headset, Superstar GTO
Wheels, American Classic 29 MTB (donated from racebike)
Frame, Pipedream Sirius Ti 29
Saddle, Charge Knife
Seatpost, New Ultimate Carbon
Seatclamo, New Ultimate
Handlebar, S-Works Carbon Flatbar
Pedals, Eggs
Cables, sealed Alligator I-link
TIA
Waiting for Godot
you might want to go with a more traditional square shaped carbon fork design for more mud clearance. the niner carbon can be snug with mud build up, YMMV depending on mud type.
also the performance access frame can accommodate the larger 2.4, 2.55 tires with room to spare, so same reason there.
sram steel cassette will last longer in the muck as well.
Out riding, leave a message
You've got some good points there. I just choose the Niner because of the weight. I have already settled on frame. Pipedream Sirius Ti 29, my life's to short for aluminium and boring frames.
30-ton War Machine
That is with a Kodiak front tire, plenty of clearance, Clarence.
Spooooon!
Go with a Salsa Mukluk for $1500 USD and then spend the rest on beer.
Looks like sufficient clearance, I think I'll stick to the Niner fork then.
I would much appreciate input on gear options? Maybe the new Shimano XT 10 speed or the new SRAM X.9 10 speed? I would like that 36T together with a 34T in the front.
SEC 10 speed gripshifter with a XTR rd on a 11-36?
Haha, not that I've ever seen og tried one, but I can't imagine it to perform very well in mud. Looks VERY heavy too.
I've used my custom steel frame / steel fork in the Danish mud for the last 18 months. My old (+4 years) Sram X.0 rear mech with alloy cage has worked very well with an XT cassette (11-34) and X.0 gripshifts. I'm running a 36T up front. In the mud you don't want bling, you just want things to work.
This winter I'm going to set it up singlespeed (32 - 21) with Nobby Nic tires. Should be a very nice winter setup.
I always want bling, but surely it needs to function properly
It's not only going to be used in mud and snow, but also in races where suspension and a 3x9 gear range is not needed.
Isn't there someone out there by now, who makes a 9 speed 11-36 cassette?
BTW rasse if you want nice mudtires, then try out the Maxxis Medusa. 500g each and twice as much traction as NN.
AFAIK the Medusa only comes in 26"...? I've used them a lot on my old bikes before going to 29er. I'm still looking for the perfect 29er winter tires...?
Ohh. I'm sorry, I just didn't realize that your winterbike was a 29'er. My bad.
Can we agree that we need a 29x2.0 Medusa then
The tread on the Bontrager Mud X TLR looks a lot like the Medusa so maybe I should try it on the rear instead of the NN...?
http://www.29squadron.com/product.php?id_product=34
For the front I don't know...maybe NN or an Ardent 2.4...?
Yeah the Mud X looks alright?!
I don't know about the Ardent 2.4 tho. Knobs looks well spaced but kinda low?
I generally like narrow-ish tires in mud but the Ardent will supply a good amount of suspension on the other hand.
I find myself in this situation often. All things has positives and negatives and it's a tough job finding the one with the least negatives and most positives.
- You may not post replies
- You may not edit your posts
Forum Rules
