Need info on the Lefty 29er- Mtbr.com
Results 1 to 2 of 2
    Hey
    Im considering ordering a Lefty XLR 29er fork. But anybody know the Axle to Crown length?
    Is it the same as a normal 26 Lefty?
    ballbuster
    Reputation: pimpbot's Avatar
    Yep!
    Quote Originally Posted by Rabbitized
    Hey
    Well, I dunno specifically about that fork. But when you take a Lefty and shorten it for 29er use, the axle to crown stays the same. You just limit the travel.
    I have a Lefty Max 140mm. The axle to crown is about the same as a Reba 29er set to 100mm. I put some spacers in there to limit the travel to 110mm, and the A to C is the same.
    Check out the Cannondale forum. There is a ton of good info there.
