Narrowed down to 3 bikes. Which should I go with?- Mtbr.com
Results 1 to 19 of 19
    Midwest riding with roots and mostly XC trails. Some trail features. 150lb rider. All are priced within a couple hundred of each other.
    2018 Scott Spark 930
    Frame: Aluminum
    Fork: Fox 34 Performance 120
    Shock: Fox Nude Evol 120
    Drivetrain: XT 2x11 (will switch to 1x11)
    Brakes: SLX
    Wheels: Syncros 25
    Dropper:Fox Transfer
    2019 Salsa Spearfish Carbon NX
    Frame: Carbon front/aluminum rear
    Fork: RS Reba 120mm
    Shock: RockShox Deluxe RT3 100mm
    Drivetrain: NX Eagle 1x12
    Brakes: SRAM Guide T
    Wheels: WTB ST i25 TCS
    Dropper: TranzX
    2020 Orbea OIZ H30
    Frame: Aluminum
    Fork: Fox 32 Rhythm 120mm
    Shock: Fox i-line DPS Performance 120mm
    Drivetrain: SLX 1x12
    Brakes: Shimano MT501 BR500
    Wheels: Mach1 Klixx 23c
    Dropper: none (might add later)
    Spark.
    Racy? Spark. Smoothest? Salsa. Chasing pivot issues? Orbea (admittedly based on a sample size of one).
    Whining is not a strategy.
    Feb 2017
    Spark.
    MTB SOCAL
    Reputation: yangpei's Avatar
    Spark / Spearfish have similar geo - around 67 degrees HA / 74 degrees SA. OIZ is steeper SA (75 degrees) but pretty steep HA (69 degrees) as well. Most newer trail bikes are moving to slacker HA / steeper SA.
    Kokopelli Racing
    "Curb drops to flat, or curb drops to transition? There's a BIG difference there." Qfactor03
    Here's what you can do on the Spark.-
    Nino does use 30mm inner width rim wheels. I'd go 40 and run 2.5 tires.
    Quote Originally Posted by eb1888 View Post
    It will turn me into a world class racer. Haha, JK. Saw that vid recently and another where a downhill guy ripping a spark rc downhill. Very capable. The 18 was sold but they gave me a good deal on a 940. Little lower spec but plenty of bike for me. Now to find a gravel bike!
    Sep 2015
    I love my new Scott, albeit a Genius.
    Will I need a side load bottle cage for the Spark? I use 24oz bottles.
    Quote Originally Posted by shades9323 View Post
    A Grip2 damper is coming for 2021 34s that will swap into your fork. Put the order in now.
    What will that do for me? Any idea on cost?
    Reputation: smartyiak's Avatar
    Having ridden the Salsa and the Spark, Id get the Spearfish...bc Id upgrade in specs as they wore out. And I like the split Pivot more than the Scott.
    YMMV
    Feb 2017
    Let me me finish that sentence ... if you are Nino.
    Jan 2016
    34 Grip2 about 340 bucks-----thelostco.com in Bellingham has them in stock-----thinking of this myself but not convinced it is worth it over the fit4---easy install Lost co has a you tube on this
    Makes a poor performing fork that can't be tuned enough into a good quality product.
    I'd call Fox on pricing.
    "The 34 pretty much just sucks across the board, unless you get a grip2 damper in it. If your only option is the fit4, the 36 is worth it for the damper alone. The 34 saves a little less than 200g, but I still think that's a very hard sell since the fork doesn't work very well."
    Post #4 in this thread-
    https://forums.mtbr.com/shocks-suspe...l#post14827395
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Well, he basically turned it into an AM bike by using a 120mm fork and a 27.5 rear wheel, the end result wasn't very indicative of what it'd be like to ride an XC race bike down a DH track IMO.
    NedwannaB
    Reputation: JMac47's Avatar
    $340 for the cartridge or sent in for them to do the mods?
    Ripley V1 XC/Gravel Adventure rig
    NORCO Fluid FS
    Salsa Timberjack
    Would that stop me from using twinloc on the front? Not that big of a deal as I have never locked out my current fork on the trail.
    i have a hard time buying fully assembled bikes. I much prefer to buy a frame and then build it up. Merlin cycles has XT drive trains for about $290 and XT 2 piston for $200 and 4 piston for $235. For wheels I tend to buy good hubs used, Im constantly monitoring for deals and always have a few hub sets. I will periodically build them up with chinese carbon rims.
    I typically will move a fork over or buy a used fork of the kind I want.
    So on a recent build the costs were something like:
    I9 torch+chinese carbon - $600
    bars/stem - $100
    seat - use existing
    XT 1x11 (crank, cassette, derailleur, shifter,bottom bracket) - $290
    XT brakes - $200
    Used 160mm lyrik fork - $350
    works headset - $75
    ks integra dropper - had it already
    So about $1600 + frame cost to get a (mostly) new bike with exactly the components I want. It lets me focus on getting exactly the right frame
  1. What bike should I Buy? Narrowed down to 3 choices
    By ihaveaquestion in forum Western Canada
    Last Post: 01-17-2012, 05:38 PM
  2. What bike should I Buy? Narrowed down to 3 choices
    By ihaveaquestion in forum General Discussion
    Last Post: 12-27-2011, 10:49 AM
  3. Which 29er should I buy? I've narrowed it down to 3
    By package81 in forum 29er Bikes
    Last Post: 05-03-2011, 08:33 PM
  4. Narrowed it down to 3 bikes, which to buy?
    By NorthBayLeo in forum Bike and Frame discussion
    Last Post: 07-22-2008, 07:49 AM
  5. Narrowed it down to 3 bikes fisher pirahna, ibex 550 or 650 which one???
    By rickytz7111 in forum Bike and Frame discussion
    Last Post: 11-10-2006, 10:22 PM
Members who have read this thread: 258
