Is my Fox F29 set to 100 or 80- Mtbr.com
Results 1 to 5 of 5
    The packaging of my new fox f29 says it is set at 80mm of travel but it came with a spacer. This leads me to believe the fork is actually set at 100mm, as the spacer is typically used to reduce the travel from 80 to 100. Can anyone offer some help on this so that I don't have to dig up the internals to find out? Thanks.
    What is the length of the exposed stanchion?
    Reputation: Flat Ark's Avatar
    Post a photo of the fork if possible. It's usually pretty easy to tell with just a glance or yeah, just measure the exposed stanchion.
    I don't have a pic on me right now. What length would the stanchion be if it were 100?
    Do you own a ruler or a tape measure? Use them.
