Mud and missing stuff...- Mtbr.com
Results 1 to 14 of 14
    Reputation: Scooty's Avatar
    The aftermath of todays ride...all I can do is laugh .
    Harshing my mellow, man..
    i can see how your crank arm fell off, stuff happens, yeah. but how do your gears just fall off? and your der's and your shifters? you got some crazy mud, man.
    In that case I guess I should thank the mud .
    broken or just not tightened and fell off?
    I'm just messing with you
    Reputation: wv_bob's Avatar
    You've got my sympathy ... 3rd ride on my Spot and the crank arm came off. Luckily I was riding flat pavement on the way to the trail head, but not so lucky because I couldn't find the bolt that fell out and let the arm come loose.
    Chasing bears through the woods drunk with a dull hatchet is strongly not advised
    Yeah I lost my bolt too. I thought my pedal was messing up about 8-9 miles into the ride, then I looked down and was like "oh crap". My multitool didn't have a big enough allen so I couldn't tighten, I got out off the trail and rode on the road with just my right leg and it fell off going uphill, haha.
    is buachail foighneach me
    Reputation: sean salach's Avatar
    looks somewhat familiar....
    original bontrager left arm loosenned itself up and came off. bolt dissappeared in the mud. last set of isis cranks i've owned, as every previous one had nearly done the same.
    Professional Crastinator
    Reputation: Fleas's Avatar
    Quote Originally Posted by Scooty
    We had a guy with a loose crank arm bolt - 10mm socket head. We came up with three 5mm allen wrenches between the lot of us and were able to tighten it.
    Of course, I know this will never happen to you again.
    -F
    Currently in Exile
    Reputation: Frozenspokes's Avatar
    Good luck ever getting that crankarm to stay on again.
    "There are those who would say there's something pathological about the need to ride, and they're probably on to something. I'd wager though that most of the society-approved compulsions leave deeper scars in the psyche than a need to go and ride a bicycle on a mountain." Cam McRea
    That's just a crappy square taper BB that came with the bike, now I have an excuse to buy new stuff, thing was creaking like a demon any ways.
    Drinker w/ Riding Problem
    Reputation: brado1's Avatar
    It was probably creaking, because it was loose... you should always do a preflight checklist, make sure stuff is tight every now and then...
    if it's square taper, and you mushroomed the crank a little, it can be fixed. i had done it once or twice back when i ran square taper, and my solution, which worked and was permanent, was to roll up little pieces of aluminum foil(like, from your kitchen), line em up in the bore, and tighten the crank down. it effectively 'cold forges' them into it.
    MTB Rider
    Reputation: willtsmith_nwi's Avatar
    Jan 1970
    Quote Originally Posted by wv_bob
    But oh so unlucky as if it's square taper, it's trashed.
    Quote Originally Posted by willtsmith_nwi
    Nope, external bearing
    Will apply plenty of Loctite and torque properly when the replacement bolt shows up (hoping for today or tomorrow). It's my own damn fault (h/t Jimmy Buffett) since I didn't check it when I got the bike.
