A monkey playing with H-bars (Cloxxki?)- Mtbr.com
Results 1 to 3 of 3
    Sep 2004
    I am almost done building my monkey with H-bars (will post pics when done). I am deciding on which Tompson post to get. Staight or layback. I know the H-bars throw things off so would a layback help with things? Your opinions would be appreciated. Thanks
    P.S. I will only use a Tompson post.
    Recovering couch patato
    Reputation: Cloxxki's Avatar
    Clearly, there's but one option for you:
    133mm stem, 8.5 rise
    12.4mm in spacers under the stem, 15.6m on top.
    H-bar mounted at a 16.3 angle, rear down.
    Seriously, without extremely tech-geeky data on your previous well-fitting bikes, it's anyone's guess. Measurements to start with could be : centre handlebar-ground and BB height. Difference between the 2 might be almost an inch more for the H, and reach (eff TT + stem) 20-30mm more.
    Klok - XC - Skate - Ski
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by Romirider
    Your handlebars have nothing to do with which seat post to use. You should set your saddle to put you in the proper position over the pedals.
    THEN you use the stem to get the bars where you need them.
    mtbtires.com
  1. What ever happened to combo bars?
    By sodade in forum Weight Weenies
    Last Post: 12-28-2004, 03:35 PM
  2. Things to know before building up a Karate Monkey
    By SpinWheelz in forum 29er Bikes
    Last Post: 11-05-2004, 03:34 PM
  3. Body Science of Handlebar "Sweep/Bend" ?
    By PiroChu in forum General Discussion
    Last Post: 09-08-2004, 07:03 PM
  4. What bars to go on the 575?
    By ride red in forum Yeti
    Last Post: 05-13-2004, 11:35 PM
  5. For fun: Dirt Rag's Monkey review
    By ncj01 in forum 29er Bikes
    Last Post: 04-27-2004, 10:38 AM
