Marathon Woes
I recently had my Marathon rebuilt by Marzocchi because the seals had blown on it. The repair was covered under warranty, so no big deal. I went on my second trail ride with the rebuilt fork today and the seals blew again...total mess, oil everywhere and a jacked up fork. Has anyone else had this problem, is this common for the Marathons? If so is there anything that can be done to help prevent this?
Don't think it's common. I've ridden mine quite frequently and never had any issues w/seals although I heard if the seals will go they go early and if they don't than your golden.
I had one of those as well
My seals broke as well, but mine did it a little more slowly. They drooped a little, and when I went to pump them up, I got oil all over. I also had Marz rebuild 'em, but I haven't had any problems yet, but only a few hundred miles since. I think that one of the problems happen when you pump up the wrong valve. If you get the negative and positive valves reversed the pressure will surely bust the seals.
Don't get stuck on stupid!
Doesn't sound common to me. I've owned 3 zoke air forks, and all held up very well.
By TrailNut in forum Shocks and Suspension
Last Post: 01-21-2005, 04:03 PM
By Archon in forum Specialized
Last Post: 11-22-2004, 08:33 PM
By dawgcatching in forum Shocks and Suspension
Last Post: 10-01-2004, 09:35 PM
Last Post: 05-25-2004, 02:50 PM
By CalPolyClimber in forum Shocks and Suspension
Last Post: 02-11-2004, 04:35 PM
- You may not post replies
- You may not edit your posts
Forum Rules
