• 09-15-2009
    MikeDee
    Light weight Slime filled tubes
    Where can I find (or make) a lightweight Slime filled tube?
    Is there a trick to mounting a 26" tube on a 29er? It took me too long to mount the tires. I'm not sure the weight savings of ~8.5" of tube length is worth the bother.
  • 09-15-2009
    mtnbiker72
    Mounting a 26" tube on a 29er doesn't take any longer than a regular tube. Inflate it just enough to give it shape, mount one side of the tire on the rim, start at the valve hole and simply stretch the tube around the rim, mount the other side of the tire...inflate.
    Lightweight slime tubes are available at most online retailers and some LBS. I know Performance carries them.
  • 09-15-2009
    MikeDee
    I'm thinking of a Slime Light 26" tube. It's supposed to weigh 219 g (which is pretty light for a Slimed tube; normal unslimed Bontrager thin 29er tubes weigh 197 g, according to Weight Weenies). Will Slime Light tube hold up when stretched inside a 29er tire?
  • 09-15-2009
    mwarner57
    I tried the Slime Light tubes on my 26er a few years ago, and wasn't too impressed. The only difference was when I pinch flatted, I got a nice neon green spray on the inside of the tire. No help at all :( Might help if you have issues with thorns, though...
  • 09-15-2009
    mtnbiker72
    Well...its like any lightweight tube...it will not be as durable as a standard weight tube. A slime light tube is a thinner tube and stretched to a 29er size will be even thinner. When I was using tubes, I mostly used 26" tubes but standard weight ones. I have consistently had pinch flat issues with lightweight tubes (which is really my main attraction to tubeless) so I myself would be more inclined to use a standard 26" slime tube and take the 90 gram penalty
  • 09-15-2009
    Dial Tone
    I have Slime Lites in my 26er and have had great results with it. Pulled over 14 goatheads (stopped counting after 14) and didnt go flat.
    I also have regular Slime tubes in my 29er--in 29 x 2.125 size. Slime doesn't make Lites in that size yet.
  • 09-15-2009
    fos'l
    Interesting and curious that you've had success with Slime tubes. I've used several of the light variety (they warrantied the first pair a couple of times) and they were "defeated" by goat head thorns. The hole, while almost imperceptibly small, wasn't plugged by the goo.
  • 09-15-2009
    jh_on_the_cape
    I use slime lite 26er tubes in my 29er. it's a bit of a pain to mount them, but not impossible.
    a better bet: put stans sealant inside a tube. a guy at the LBS does this for me. i think it would be a pain to do it, but he is all set up. giant bottle of stans with pump dispenser - clear tubing of the correct size, and a case of tubes with removeable valve cores. he just unscrews the core, connects the tube, pump pump, then puts the core back in and gives them to me for the price of a tube.
    that mechanic has since left, and i am almost out of those tubes...
  • 09-15-2009
    Dial Tone
    Maybe the sealant was old? I thought I read it somewhere that the sealant has a limited lifespan.
    I pulled out the thorn, green slime oozed out, spun the wheel until the hissing stopped. Repeated 13+ times more. And though the tire did not go flat, I did have to pump a little bit of air back in. I continued to use the same tube until I replaced it last month. I tweaked the valve a bit and air would slowly leak out. To be on the safe side I just bought a new tube just in case the sealant had dried/aired out. Tube was used from June '08 to Aug '09.
    So far no pinch flats--though I always inflate somewhere inbetween the min and max PSI. And I always carry spare tubes anyway. You never know you might run into someone who might need one.
  • 09-15-2009
    Pivvay
    I've had terrible luck with lightweight 26" slime tubes in a 26er or a 29er. I've given up on them actually.
  • 09-15-2009
    Ken2
    Flat Attack
    Flat Attack makes a line of tubes with their sealant that includes 29er tubes.
    Or you can buy Flat Attack goo sealant and add it to any tube, provided it has a removeable core (Q-tubes have them, not sure about others). They include a rubber hose that fits perfectly so there's no mess.
  • 09-15-2009
    Natalie Portman
    I concur.
  • 09-15-2009
    Jay P
    I rode 3000 miles on Slime 26" tubes on my tandem 29er! No kiddin, even next to you for some :).
    And you tubeless lovers should really look into the Slime Pro Tubeless.
    -JayP
  • 09-16-2009
    Pivvay
    -JayP
    I know Jay and that's partially why I'd been stubbornly trying them as my "backup" tubes. But on the rare occasion that I've flatted my Stansed tires or ran out of sealant, the slime lite tube in my seatbag was either already failed despite being wrapped up protectively or it failed within the next couple hours.
    The non-lite version seems to work fine, but the lite version just has not worked to for me and I've bought at least 6 of them at full retail over the past 2 years thinking I was just getting unlucky.
  • 09-16-2009
    Guitar Ted
    I have no idea if my tubes are Slime Lites or regular Slime tubes. (I am guessing they are Lites, because I got them handed down to me by endurance racer Jeff Kerkove) Anyway, they have to be four years old now and have been swapped from wheel set to wheelset and used on several different bikes. Still going strong with zero flats. These are 26"er tubes, by the way. easy to mount if you take your time.
    I have also had good success with injecting CaffeLatex right through a Presta valve stem.
    YMMV.
  • 09-16-2009
    Boyonabyke
    Kenda now makes presta valved tubes with removeable cores so you can slimes or stans them yourself. I don't like Stans in a tube... it takes 2 months for it to turn into lumpy asteroids inside the tube, with no way to get them out of the tube. Goat head season around here is from mid August through mid October, so I'll slime up a tube and run it for 3 months, and when the rear tire wears out, I'll just put in a new tube with a new tire, and not haul all that sloshing mess around.
    http://www.kendausa.com/_DOWNLOADS/P...CcatalogLR.pdf
    Page 22 has the goods.
  • 09-16-2009
    MikeDee
    YMMV.
    There's a discussion on the Flat Attack website that says that lightweight tubes don't work well with sealants (something about needing to have a certain wall thickness through the hole for the sealing particles/fibers to cling to). This would indicate that Slime Lite tubes don't work as well as regular Slime tubes do.
    Does CaffeLatex rely on particles/fibers to do the sealing? If not, then it may work well with a lightweight tube. How much is needed for a tube? Do you have to have a removable presta valve to get it in?
  • 09-16-2009
    MikeDee
    I have Bontrager tubes with removable presta valves. Also, I hear that Continental tubes have removable presta alves.
  • 09-16-2009
    Guitar Ted
    CaffeLatex is a synthetic latex with no ammonia. It seals up punctures in a similar way to Stan's, so no "fibrous" stuff here. That's why you can inject it right past a valve core. They have an injector kit that makes this a snap to do, but I think you could make something with a small baster (kitchen tool) and a length of shrink tubing as well.
  • 09-18-2009
    eyescream
    What a waste of $$ the "Slime Lite" 26"er tube was...lasted all of 30 minutes into a ride.
  • 09-18-2009
    boomn
    After doing research about tubeless and reading how regular bike Slime simply isn't good enough to ever work for tubeless, I started to wonder what made Slime actually work for tubes. Apparently the answer is: nothing. I have had to help a friend with a flat in his Slime tube before too. Just a little pinch flat but it would not seal.
    I would highly suggest making your own. Start with a regular 26" tube with either a removable core presta valve or a schraeder valve. Add Stan's or the homebrew tubeless sealant. Ride
  • 09-18-2009
    longman
    did ~4000 miles
    this summer on the gdmbr with side trips along the way on a loaded 29er and didn't get a single flat in my slime tubes....the first night I pulled about 80 goatheads out of my tires when I camped near the abandoned houses in Separ NM, just spun the wheels and they sealed right up.
    Pivvay...I said hello as you left Kremmling and rode with you for a few miles
    JayP...you sneaked past my tent earlier the same morning!
  • 09-18-2009
    Jay P
    You should try Slime Pro Tubeless not the standard bike Slime for your tubeless setup. The Tubeless version last a long time in comparison to others drying up too.
  • 09-18-2009
    boomn
    I had researched enough before hand to know not to use regular Slime, thankfully avoiding that hassle.
    I ended up with the homebrew recipe from this forum and it has worked great:thumbsup:
    I might consider other sealants once I eventually run out of the current batch, but from what I remember my ingredients cost about twice as much as a small bottle of Slime Pro but created about five times as much sealent
  • 09-19-2009
    jsord
    been using lite slimes 26" for 5+ years - can't remember my last flat .... i've had 2 on my new 29r in the last week - it now has 2 new slime tubes ;)
  • 09-22-2009
    Pivvay
    Longman it was nice to ride with you out of Kremmling!
  • 10-01-2009
    THATmanMANNY
    I've heard of Stans lasting for nearly a year? Any input?
    YMMV.
    Are you using the CaffeLatex in an inner tube? How much did you put in? I was just thinking about Stans in my inner tubes. How much should I put in?
  • 10-01-2009
    Guitar Ted
    Best I've gotten out of Stan's is six months before it boogered up.
    Yeah, I put in two ounces and it still is going strong since about early May.
  • 10-01-2009
    randyharris
    I tried a method of pushing the presta valve into the tube, putting in Slime, then pulling the presta valve back into place - I couldn't get it to work for a darn. I didn't realize that CaffeLatex could be injected in to a presta tube with the valve in place.. Very Interesting...
    Does anybody have experience with this? I ride in thorn riddled Phoenix desert trails and some flat protection would be great.
  • 10-01-2009
    MrHappyMedium
    You can make a small cut your presta tube, put the Slime in and patch the tube. Cheap way to do it vs the pre-filled tubes. Just wait for the slime to move away from the hole before patching.
    If $ = time it's not the way to go, but I have a bike budget and I don't make any money when I'm at home ;)
