Lenz Info- Mtbr.com
Results 1 to 8 of 8
Thread: Lenz Info
    Big Wheel Homer !!
    Reputation: cruzthepug's Avatar
    Lenz Info
    Can one of you guys with a large Lenz tell me how long the head tube is? I just ordered a WB BW 0.8 (sweet deal ) to use on my KM, but I'm thinking about a Lenz or one of the other new FS coming out this spring and I want to swap it over. The HT length on a Asylum is 4.0" and the monkey is 3.7" so that's not a problem, but if I run into a 5"+ HT it won't work unless I use a ton of spacers now. Ideas?
    thanks
    cruz
    The Duuude, man...
    Reputation: ncj01's Avatar
    Quote Originally Posted by cruzthepug
    thanks
    cruz
    <img src="https://img.villagephotos.com/p/2004-10/867718/81741086-DSC_0001.JPG">
    FS: Everything
    Big Wheel Homer !!
    Quote Originally Posted by ncj01
    Thanks, that tells me what I need to know. Save $ for a second WB.
    jl
    jl is offline
    climb
    Reputation: jl's Avatar
    Hold The Phone
    That's the XL size!
    L = 4.5" if it makes a difference. (?)
    We don't need more to be thankful for; we just need to be more thankful.
    Big Wheel Homer !!
    Quote Originally Posted by jl
    That's the XL size!
    That does work alot better, less spacers. I don't like the look with a bunch of spacers. Thanks.
    The Duuude, man...
    A couple things:
    1) if you have to run a lot of spacers but don't like the look, place a few of them under the stem, and a couple above..you can suck up a lot of extra steerer tube without it lookin' that bad at all....also there are places to get really cha-chingish spacers, like Seven Ti spacers..
    2) WB will press a new steerer into an existing fork for a song and a dance.
    FS: Everything
    Recovering couch patato
    Reputation: Cloxxki's Avatar
    If would be nice if there were headset lower cups with some 15mm extra height built-in. Might not attract too much attention. I've been thinking about headtube extenders, also for geometry reasons, but that never materialized so far.
    One guy (Bram on here) I know once ran spacers UNDER his headtube to lengthen a cross fork for 29" use, and got it to work with an extra headset race of some sorts. That was intergrated ahead, though.
    Klok - XC - Skate - Ski
    Big Wheel Homer !!
    Quote Originally Posted by Cloxxki
    Well, I guess what I'll do is just have the WB cut about the same length as I have the KM fork now (using about 25mm spacers, which is more than I like but for some reason I'm always thinking about the future). If the WB won't work on the FS frame I end up getting I'll just get another WB. I don't know what they charge to press in a new tube and add shipping both ways, but I can get a new WB for $480.
    thanks guys,
    cruz
  1. Any info for Summit Frames?
    By russw19 in forum Custom Builders & Other Manufacturers
    Last Post: 08-02-2004, 10:06 PM
  2. Replies: 17
    Last Post: 07-30-2004, 07:18 PM
  3. Heartland Race Series Races #5&6 June 12&13th info
    By mward in forum Great Plains - OK, KS, NE, SD, ND
    Last Post: 06-03-2004, 01:48 PM
  4. Any info on Plattekill race this weekend
    By stinkydropoff in forum Downhill - Freeride
    Last Post: 03-27-2004, 06:41 PM
  5. where is trek's archived bike info
    By fatroadie in forum General Discussion
    Last Post: 02-18-2004, 04:17 AM
