Length of Thomson Setback Seatpost- Mtbr.com
Results 1 to 5 of 5
    Feb 2010
    So I'm building up a Jamis Dragon 29er, 19" Frame. I'm 6'2", is there a default seatpost length to go with to get the right height. I'm set on the setback and I think the 330mm will work. Thoughts? Thanks in advance.
    Reputation: mitzikatzi's Avatar
    I ride a 19inch Monocog with a 400mm seat post and I am about the same size as you. Easier to cut a 400mm down if it's too long rather than try and add some.
    Hard to say with out knowing your inseam.
    But unless you have a 32 inseam, you are probably looking at a 350 minimum
    What is your seat height.
    Often about 110% of inside leg measurement (max).
    So crank length + frame length (19 inch if c to top) + seat post length + thickness of seat = seat height.
    7+19+10+2 =38 inches seat height is about the max with a 400mm post with 300mm of post showing
    You want at least 4 inches of post in frame. Work out seat post length you need.
    The Duuude, man...
    Reputation: ncj01's Avatar
    Becuase your frame is too small for you, you'll probably need the longest post made. I think they make a 400 and/or a 410....
    FS: Everything
