Recieved my complete inbred right before Xmas. Then the weather turned warm, it rained a lot and for almost two months the Inbred sat clean and fresh. Weather finally gets cold, ground takes a few days to freeze, and I finally have a chance to try her out. I take the day off work because I am leaving the country for a few weeks and everything looks good to get in at least one good ride before I leave. Then I eat my wifes cooking, suffer through a night of something, who knows, might have been the malaria pills they put once a day on the bottle instead of once a week, doesn't matter, I feel like an abused dog. Decided what the hell, can't feel worse, takes me two hours to get moving but I make it to the trail. I was just really starting to enjoy things and about two miles in this happens :
So, where do I get a steel 32T front ring?
Were you using alloy chainring bolts? Our findings are that the aluminum chainring is not usually the weakest point. If you use aluminum chainring bolts, this will almost always be the result. Might be worth checking out before you put a steel ring on, although I guess you have to buy a new ring anyway.
It doesn't look like this was the case from the picture, but a loose or missing chainring bolt can wreck a 4 hole chainring right quick. Check your bolts, guys and gals!
I suppose there's another good argument for steel rings; They can bend without breaking.
Thanks for the tips. It is a truvative crank, stylo GXP, comes stock on the On One complete 29er. I am a clyde as well and it is obvious that we just have too much power...or fat, either way the chainring lost.
Not sure about the bolts, too tired getting ready to leave to check. I will take a look at the Ti and steel rings with a nice set of steel bolts. I would bug Brant at On One but I can't really expect him to do more than send a replacement ring and that is a waste of time for both of us.
Oh, you cannot tell in those pictures but the ring is not even round, or close to it, it is well into the oval.
