jet 9 rdo works angled headset?? 2014 jet 9 rdo- Mtbr.com
Results 1 to 9 of 9
    Apr 2015
    hey i was wondering if a works angled headset would work on my 2014 niner jet 9 rdo. i want to slacken it out 2 degrees. wich one should i get theres like 10 different sizes
    Reputation: RS VR6's Avatar
    I don't think you can run an angleset on an internal bearing headtube.
    Apr 2015
    hmm
    Mar 2015
    If you want to slacken your head angle your option is to use offset bushings in your shock. You change the head angle up to 1.5 degree. Your bottom bracket will also drop which can be a good or bad thing depending on your trail. Offsetbushings.com - Standard & Offset bespoke bicycle shock hardware ? Offset Bushings | Shock Hardware
    Apr 2015
    Oh Do these bushing go on the shock or the actual pivot. These look good quality have you used them before?
    Mar 2015
    They go on the shock bushings. No special tools needed, you install them by hand and it's a about a 5 minute job. I have them on my rocky mountain altitude and they work great. Best bang for the buck to slacken head angle and lower the BB height.
    Apr 2015
    nice how long do they take to get to youre house?they come from the uk right?
    Rocks belong
    I've got a brand new 22mm x 6mm Burgtec Ti offset shock bushing that'll work great for the lower shock eyelet of your Jet9. PM me if you'd be interested. You could also put it on the upper eyelet, but that's a high rotation link. It'd be better suited on the lower eyelet.
    I like 'em long, low, slack and playful
    Mar 2015
    Quote Originally Posted by Juan Flores View Post
    It took 6 days to get the bushings delivered in California. It was shipped through the mail.
  1. 2014 S-Works Epic vs. 2014 Scott Spark 900 SL
    By OCDirt in forum Specialized
    Last Post: 04-03-2014, 09:30 AM
  2. 2014 Spark 900 SL vs 2014 Specialized S-Works Epic
    By OCDirt in forum Scott Sports
    Last Post: 03-30-2014, 04:38 PM
  3. Replies: 8
    Last Post: 01-10-2014, 08:29 PM
  4. Angled headset options on a TRc
    By dromond in forum Santa Cruz
    Last Post: 11-09-2012, 05:15 PM
