I9 Enduro S 29er
Printable View
  • 08-06-2018
    mcozz421
    I9 Enduro S 29er
    I am buying some Industry 9 Enduro S wheelsleets. Internal width = 30.5mm/Outer Width = 34.1 mm. Website says these are rated for 2.3" - 2.8" tire sizes. They obviously don't make 2.8" 29er tires, so will this wheelset be sufficient for 29er 3.0. Let's say WTB Ranger 3.0s?
  • 08-06-2018
    eb1888
    You can run them, but you'll have to use higher pressure than if you use a wider rim. Cuts somewhat the value of the wider tire's potentially larger footprint for traction.
  • 08-06-2018
    Arctic Pride
    WTB makes 29 2.8's
  • 08-06-2018
    Dale-Calgary
    Ibis 942's might be better for you
  • 08-07-2018
    mcozz421
    I am trying to stay under 1K for pricing. I did look into your Ibis recommendation and saw that they have an aluminum wheel set that 38 mm OW/ 34 mm IW. The 942s have an IW of 35 mm. With that difference being 1 mm (hopefully negligible) would the Ibis 938 be ok to run 3.0s on?
