Front Surly Tires- Mtbr.com
Results 1 to 3 of 3
    Front Surly Tires
    I've been seeing a lot of large tires on the front end of rigid 29er's. Most riders are putting Surly Endomorphs or Surly Larry 3.8 tires on a 26" rim as the front wheel. Guess it's a for shock absorption?
    Anyone know the reason behind the bigger tire? Interested in trying it out.
    Missouri sucks...
    Sand, snow, crotcheral region insecurities... Who knows
    Reputation: davesauvageau's Avatar
    Mostly for the floatation over snow and loose ground. If you check out the Fatbike forums, there are several half-fat bikes. I have a Pugsley and a 29er and they both feel great, so I would bet that half-fat is a good combo. Are you going to run the 100mm Surly fork or the 135mm Surly fork?
    My motorcycle runs on infant blood
