Fixed Gear 29er Anyone have 1 ?- Mtbr.com
Results 1 to 8 of 8
    Reputation: imtb's Avatar
    Trying to find more out about a 29er fixed gear anyone riding 1? What gears are u running, Do you have any pics to post. Any info would be helpful. I am thinking about building one.
    ride on....
    Just Ride!
    Reputation: kustomz's Avatar
    I have never ridden fixed gear.......... would that require something different than a standard ss'er ?
    Witty McWitterson
    Reputation: ~martini~'s Avatar
    I used one last year for Ice races, but haven't ridden off road fixxed. I can't remember the gear I used though...sorry.
    Just a regular guy.
    Needed Less ~ Did More
    Reputation: Singlespeedpunk's Avatar
    Well....
    I don't have a 29er, but I have run fixed off road on a 26er for a bit so heres what I know....
    Run a larger gear than you would on a freewheel.....your legs need to spin on the down hills! 36:16 for flat-ish places, 36:18 in the winter/mud/un-fit season. (vs. 36:18 / 36:20)
    Get a good quality cog and lockring: Surly, EAI, Dura Ace. Cheap cogs have little thread and can trash hubs....not fun (same goes for lock rings!)
    Keep BOTH your brakes to start with, then ditch the back one if you want.
    Keep pedling!
    Try www.63xc.com for lots of info.
    Good luck
    Alex
    "Put any one on one of these singlespeed bikes and they could not help but have fun"
    Otis Guy talking about klunkers c1976
    Reputation: happygofun's Avatar
    almost a 29" fixed
    I have a surly cross check that I ride fixed off-road. Currently only have some 700x32 ritchey speedmax's on it but other wise ride larger volume. A good gear I've found for rolling hills is 42x17 though it can take a bit of grunting.
    Having ridden single speed and fixed I'd say that it's easier to puch a harder gear on a fixed. The fixed wheel doesn't loose momentum like a freewheel.
    I definately recomend trying it, quite fun.
    Stokeless Asshat
    Reputation: jeff's Avatar
    Fixed 29"er
    I ride my Mutiny Man fixed part of the time.Phil/Dyad flip flop hub.I`m currently running a 2x2 set up.Synchros cromo crank,Salsa rings,AC 20t freewheel and a Surly 16t track cog.Same chain length base on the 4 tooth rule.The 36/16 is a good town gear,not the best but it works.No balls to take it off road fixed though.
    Jeff
    Just got done riding it to work
    I ride my Karate Monkey fixed to work nearly every day. I ride 42:18. I posted some pics awhile back in this forum. Look for HisNameIsPeterIKnowHesOutThere if you don't find them, let me know, and I will repost them for you.
    Reputation: qtip's Avatar
    I ride my monkey fixed
    I've got my KM set up with a Phil fixed/free. I ride 32:15 fixed w/out a rear brake as my to the trailhead gear, and on some flatter trails, and commuting gear. I don't mess with re-adjusting the rear brake when I flop the wheel (32:20 w/ a freewheel), just use the front brake and my legs to stop. I've been riding my cyclocross fixed off road for over a year, and commuting fixed for a few years. I'd recommend a rear brake if you are just getting started in off road fixed riding.
  1. having trouble finding a size small 29er
    By sam in forum 29er Bikes
    Last Post: 01-23-2004, 02:16 PM
  2. Paging Shiggy: Bontrager 29er 2.2
    By Padre in forum Singlespeed
    Last Post: 01-16-2004, 02:21 PM
  3. Replies: 3
    Last Post: 01-16-2004, 08:39 AM
  4. Why I ride a 29er....
    By Padre in forum 29er Bikes
    Last Post: 01-14-2004, 04:44 PM
  5. Member list is now fixed!!!!
    By fc in forum Site Feedback/Issues
    Last Post: 01-03-2004, 07:38 AM
