first ride....- Mtbr.com
Results 1 to 8 of 8
Thread: first ride....
    Dec 2004
    first ride....
    I just finished putting together a used Kelly Ro sham bo. Went out tonight (brrrrrrr) and ran into a problem. When I really torqued on the cranks in a low gear, there was so much flex that it would actually drop the chain!! I'm guessing that either I'm too big (6'2" 190lbs) to ride light-weight steel frames, or something's wrong with the bike. Is the latter is true then what could it be? Bent der hanger? I'm all ears..
    Where's Toto?
    Reputation: endure26's Avatar
    When you say "drop the chain" I'm assuming you mean off the front end...
    Not so bad: bent chainring(s), chainring bolt(s) loose, crank bolt needs tightening, front deraileur out of adjustment (mis-aligned cage), excessive play in BB
    Bad: You're too big, frame is misaligned, frame is damaged
    Dec 2004
    kinda
    What happens at first is a small jump in the chain at the rear der, then if I really get on it there's all-out major chain-suck.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by new kelly
    New or used chainrings?
    mtbtires.com
    Dec 2004
    used
    it's a used xtr crankset (952).
    Big Wheel Homer !!
    Reputation: cruzthepug's Avatar
    check the chain to make sure you don't have frozen link. If the chain is not bending when it goes thru the derailleur it can hang up sometimes.
    Steve
    Where's Toto?
    Make sure you don't have a stiff link. You can spin the crank backwards. Watch for a link to jump when it hits the deraileur pulleys. Check the section of chain that jumps for a stiff link. If the link is stiff, give the chain a little flexing back and worth sideways to loosen it.
    Also, make sure the chain your using is compatible with the cassette - ie you're not running an eight speed chain on an nine speed cassette or vice versa.
    Bored
    Reputation: bigwheelboy_490's Avatar
    Jan 2003
    I think Shiggy Nailed it on the head..
    Used chain rings and a new chain can be a bad combination. Try replacing the rings and have a fresh Drive train. I'll bet the problem will go away.
    MTBR is serious stuff.
    You never get better until you get out of your comfort zone.
  1. Is there a better way to start the New Year? a ride report
    By Yeti_Rider in forum Riding Passion
    Last Post: 01-02-2005, 04:46 PM
  2. Replies: 7
    Last Post: 08-16-2004, 01:42 PM
  3. Replies: 27
    Last Post: 08-16-2004, 10:15 AM
  4. Replies: 4
    Last Post: 08-12-2004, 08:45 AM
  5. AZSF04 Spring Fling Pre-Gathering Organization thread
    By AZ Mikey in forum Riding Passion
    Last Post: 03-29-2004, 06:15 PM
