Felt Nine 1 or Felt Nine 2 ??...- Mtbr.com
Results 1 to 5 of 5
    Jan 2014
    I made up my mind a few weeks ago about getting the new Felt Nine 2, however I found a very good deal for the Felt Nine 1 and now I am wondering which one should I get.
    It's going to be my first MTB for over 15 years (I am a road cyclist), and I am not sure if it's worth spending the extra 1.100 euros for the Nine 1
    I am planning to ride the new bike 4-5 days a week, doing 60-100km x day XC/Rally style rides.
    I know all the upgrades I get on the Nine 1 (including the different frame) but will it really make a difference?
    Has anyone riden one or both of these bikes?... Any thoughts about which bike should I get will be appreciated!
    Thanks in advance!!
    The Felt Nine 1 29er screams race ready with is Felt's proven podium winning built made from premium UHC Advanced carbon fibre Nine frame matched with full SRAM X0 2 x 10 components and a World Cup winning Rockshox Sid 100mm fork. The Felt Nine 1 is the perfect balance of incredible ride quality ad razor sharp handling that will lift your A game to help you beat the competition, you just need to supply the legs!
    Specifications
    SKU FENINE1
    Manufacturer Felt
    Model Nine 1 29ER
    Colour Matt Carbon
    Frame Felt Nine Series XC, UHC Advanced carbon fibre, InsideOut internally optimized molding process, Modular Monocoque Construction (MMC), full carbon dropouts, ControlTaper head tube, Kevlar chain watcher, replaceable derailleur hanger, internal derailleur cable routing w/IS disc mounts, standard 73mm bottom bracket, 135mm OLD, 27.2mm seatpost, 34.9mm high clamp front derailleur
    Sizes XS (14"), SM (16"), MD (18"), LG (20"), XL (22")
    Fork RockShox Sid RL, 100mm travel, PushLoc remote lockout, adjustable rebound, tapered aluminium steerer, magnesium lowers, 15mm Maxle, post style disc mount
    Headset FSA No.42 integrated tapered Aheadset, custom cone spacer 1 x 8mm + 3 x 5mm straight spacers, w/ Felt Tornado aluminium top cap
    Stem Felt MTB 3D-forged threadless 1-1/8" +/- 7 rise for 31.8mm handlebar w/ CP Cr-Mo bolts: XS - 70mm SM/MD - 80mm LG - 90mm XL - 100mm
    Handlebars Felt MTB flat carbon, 9 sweep, 720mm wide
    Grips ESI Racers Edge, silicon
    Bar Ends ESI end plugs
    Shifters SRAM X0 2 x 10-speed
    Front Derailleur SRAM X0 high clamp 34.9mm bottom pull, 2 x 10-speed
    Rear Derailleur SRAM X0 Type 2 10-speed medium cage
    Crankset SRAM X0 2 x 10-speed: XS/SM - 170mm MD/LG/XL - 175mm
    Chainwheel SRAM 38/24T
    Bottom Bracket GXP
    Pedals n/a
    Chain SRAM 10-speed
    Freewheel SRAM 10-speed 11-36T
    Brake Levers SRAM X0
    Brakes SRAM X0 front disc w/180mm rotor
    Cables Felt All-Weather Sealed Slick
    Saddle Prologo Nago Evo X10, w/ ultralight shell & Cr-Mo rails
    Seat Post Felt UHC Performance carbon shaft, 2-bolt micro adjust, low-profile forged head & forged rail clamps: SM - 27.2 x 350mm MD/LG/XL - 27.2 x 400mm
    Seat Post Clamp Aluminium 6061 CNC cold forged w/ barrel nut design, 31.8mm
    Rims MAVIC Crossmax 29 tubeless ready
    Front Hub MAVIC Crossmax 15mm axle
    Rear Hub MAVIC Crossmax ITS-4 freehub, 10-speed, 6-bolt disc mount, 135 x 10mm axle
    Spokes Straight pull aluminium w/ self-lock aluminium nipples
    Tyres Continental X-King ProTection tubeless ready folding, 29 x 2.2
    Weight to be announced
    Year 2014
    The Felt Nine 2 is a race ready 29er cross-country bike that is built from premium UHC advanced carbon fibre Nine frame, Rockshox Reba RL 100mm fork, and a good mix of Shimano Deore XT 2 x 10 components topped off with a Mavic Crossride wheelset. The Nine 2 is a no compromise bike that provides incredible ride quality and performance that no other brand can bring enabling you to rip through miles of singletrack with no limits.
    Specifications
    SKU FENINE2
    Manufacturer Felt
    Model Nine 2 29ER
    Colour Matt Carbon
    Frame Felt Nine Series XC, UHC Performance carbon fibre, InsideOut internally optimized molding process, Modular Monocoque Construction (MMC), full carbon dropouts, ControlTaper head tube, Kevlar chain watcher, replaceable derailleur hanger, internal derailleur cable routing w/IS disc mounts, standard 73mm bottom bracket, 135mm OLD, 27.2mm seatpost, 34.9mm high clamp front derailleur
    Fork RockShox Reba RL, 100mm travel (80mm/XS), Solo Air, PushLoc remote lockout, adjustable rebound, tapered aluminium steerer, magnesium lowers, 15mm Maxle, post style disc mount
    Shifters Shimano XT Rapid-Fire 2 x 10-speed
    Front Derailleur Shimano XT high clamp 34.9mm, bottom pull 2 x 10-speed
    Rear Derailleur Shimano XT 10-speed long cage
    Crankset Shimano XT Hollowtech II 2 x 10-speed: XS/SM - 170mm MD/LG/XL - 175mm
    Chainwheel Shimano 38/24T
    Bottom Bracket Shimano sealed threaded
    Pedals n/a
    Chain Shimano 10-speed
    Freewheel Shimano 10-speed 11-36T
    Brake Levers Shimano Deore
    Brakes Shimano Deore disc w/160mm 6-bolt rotor
    Saddle Felt MTB performance w/ Cr-Mo rails
    Seat Post Felt butted aluminium 6061, 2 bolt micro-adjust 15mm offset: XS/SM - 30.9 x 350mm MD/LG/XL - 30.9 x 400mm
    Seat Post Clamp Aluminium 6061 CNC cold forged w/ barrel nut design, 34.9mm
    Rims MAVIC Crossride 29
    Front Hub MAVIC Crossride 15mm axle
    Rear Hub MAVIC Crossride FTS-X freehub, 10-speed, disc mount, 135 x 10mm axle
    Spokes Straight pull bladed w/ self-lock nipples
    Tyres Continental X-King SL folding, 29 x 2.2
    Year 2014
    Nine 1 weights 10 kg
    Nine 2 weights 11,2 kg
    Attached Thumbnails Attached Thumbnails Felt Nine 1 or Felt Nine 2 ??...-nine2_int_1.jpg
    I see you have a Felt road bike but---
    The 71.5 head tube angle is too steep for my riding. I would demo the bike on trails before buying. That ht angle with 46mm offset forks can be too twitchy on technical downhill runs. I would include two other bikes before making a move. Top pick would be a Trek Superfly 9.6 with a Motion Control DNA RLT damper upgrade to the fork(SID part). Good geo with 51mm offset fork and top damping carbon frame with the help of their road frame engineering group.
    Superfly 9.6 - Trek Bicycle
    Second would be a Canyon Grand Canyon CF SL 6.9 or 7.9SE.
    https://www.canyon.com/_en/mountainb...69#tab-reiter2
    Trail Ninja
    Reputation: Varaxis's Avatar
    Between those two, go with the better spec'd 1 for sure. No question about it. Better performance that you can feel from the higher quality tires, wheels, fork, and lighter parts that probably drop weight by about 2 lbs. People would pay well over $1000 to drop that much weight off a top end bike.
    HA is fine. 71d might have been the standard for 26" XC, but with bigger wheels 71d feels slacker. Not odd to see some bikes with 72d, like the Open O1. Felt's pushing into the MTB market harder lately, so I'm curious about how they ride. They picked up former Intense guy who had a big hand in making the Spider 29 Comp, who should tune their trail bikes to feel pretty good. XC bikes are a different story, and I can't predict how they would handle. They seem to have an open mind about carbon and how to tailor it, if their tri bike designs are to be an indication, but I for sure wouldn't expect Trek and Spec levels of refinement. I would pit them against a brand like Rocky Mtn to see how well thought out the ride feel is, but Rocky's from Canada and Felt's from SoCal, and I imagine that the local riding conditions are a huge influence on ride feel refinement.
    Jan 2014
    Thank you eb1888. I think I won't be able to test the bike on trails before buying, although I'd love too! I am actually riding a borrowed 27,5 KTM Ultra and I have ridden it on difficult terrain and on technical runs and the bike behaves well and I feel very comfortable all of the time, however I can't find this bike geometry anywhere to compare it to the Felt.
    Thanks for the bikes you recommend, I certainly like Trek and Canyon bikes... Superfly's HT angle is 69,6, the Canyon is 70 degrees, and Felt is 71,5... My height is 5' 7' so bike size will be a M. Such a difference in angles and considering its a 29er shouldn't have to be a problem, but I get what you saying if we also put into the equation the 5mm shorter offset forks the felt has vs Trek. I'd love to try both!
    Jan 2014
    Thanks Varaxis! I heard some really good things about Felt's 2014 XC bikes and since I have been riding Felt carbon road and tri bikes for the last 4 years and I only have positive things to say about them, I thought I'd look into their Nine XC line for my next purchase.
    Perhaps Trek, Spec (or Cannondale) levels of refinement are higher than Felt, but I believe the price-quality relation you get with Felt bikes is pretty good (or so it seems looking into this year Nine bikes) (and besides I get a pretty good cut off the price on the Nine 1 too from my local shop!), but I can't really say how they ride because I haven't tested them.
  1. Felt Nine 20
    By bstoic in forum Beginner's Corner
    Last Post: 05-06-2013, 08:48 PM
  2. Felt NINE C
    By KushGT3 in forum Felt
    Last Post: 04-14-2013, 07:41 PM
  3. Felt Six 80
    By fondoo in forum Felt
    Last Post: 09-22-2012, 05:21 AM
  4. felt vs felt vs scott - best bang for buck
    By xianmacx in forum 29er Bikes
    Last Post: 07-14-2011, 10:10 AM
  5. I shouldn't of done this (Felt HT)
    By thecanoe in forum Felt
    Last Post: 04-05-2011, 12:36 PM
