Fantom 29 rear tire clearance?- Mtbr.com
    Jun 2010
    Hey all,
    Thinking of running a pair of 2.4 RR's on my Fantom29, wondering about rear clearance. Can't find much info searching around.
    Former Bike Wrench
    I know Nevegal 2.2's fit which are actually the same width as the RR's, but the RR's are 5mm taller which may or may not make a difference.
    Not sure if this helps, but here is the chart I'm using to compare
    http://mtbtires.com/site2/tire-specs...00c-tire-specs
    Rider and Wrench
    Reputation: knottshore's Avatar
    I am pretty sure you won't have an issue (sorry for the less than solid response...) I have run Weirwolf 2.55's and there was still loads of room, and have run the RR 2.4's so have a pretty good feel for them size wise. What rim are you running?
    I Just wish I could ride more!
    Jun 2010
    WTB FX28. On the wide side at 28mm, I believe.
