Results 1 to 6 of 6
    Oct 2018
    Dropper post specs for 2015 Specialized FSR Stumpjumper Comp 29er
    I have the opportunity to buy my first FS bike, a 15' Stumpjumper. It doesn't have a dropper post on it and I can't find the specs to find out if it set up for an eternal or external dropper. Anyone know or happen to know where I can find specs for this bike?!
    jcd's best friend
    Reputation: Battery's Avatar
    May 2016
    You can probably look at stock photos to see. My 16 Stumpy had an internally routed dropper.
    Trek Emonda | Transition Sentinel
    jcd's best friend
    May 2016
    Oh wait I understand your question better. You want t to know if itís internal or not. The bike came with a non-dropper seat post instead of the Specialized Command Post so I would assume itís external. However, the S-Works model had internal routing so there is a chance the comp model could take internal routing too.
    Mar 2015
    Aluminum is external only unless you drill a hole in the down tube.
    IIRC the carbon frame could be routed since it is open mold.
    Here is a picture of a modified 2015 frame. Obviously drilling voids any warranty and you risk scarring the paint if you are not very steady with your pilot hole and tapping for the hole.
    Mar 2015
    Dec 2018
    I have the same bike. The shop where I bought the bike installed the internally routed post for me a year after I bought the bike. The cable is exposed on the down tube (. As are all the other cables), but they drilled a hole in the back bottom of the seat stay tube and ran the cable internally up to the post. I love the post and have had no problems with it. They charged me $35 C for the install.
  1. Replies: 0
    Last Post: 09-17-2018, 08:36 AM
  2. Replies: 12
    Last Post: 07-31-2015, 11:41 AM
  3. 2015 Stumpjumper comp 29 vs 2015 Stumpjumper comp carbon 29
    By Ngangen99 in forum Beginner's Corner
    Last Post: 02-25-2015, 02:48 PM
  4. Replies: 10
    Last Post: 06-23-2013, 01:08 PM
  5. Replies: 14
    Last Post: 04-09-2012, 09:54 AM
Members who have read this thread: 15
