Disc rotor question...- Mtbr.com
Results 1 to 3 of 3
    Just wondering if I will have any problems using other brand (Hayes) 160 rotors on a second set of wheels to be used with my Avid brakes.My LBS only has 1 Avid in stock and it is $10 more than the Hayes rotors.They have a bunch of Hayes.
    Just wondering if they are the same thickness or might cause weird pad wear.
    Thanks,Dan
    no signature
    Recovering Weight Weenie
    Reputation: Padre's Avatar
    Quote Originally Posted by dfcas
    Thanks,Dan
    No problem.
    You might have to play with the caliper alignment again but it will work.
    Check what size your Avid rotor was, 160 or 165.
    Your pads won't know what thickness your rotor is...and I'm not telling.
    Don't like it....
    I tried the second set and the Hayes rotors are thicker.To be used alone would be fine.but to do quick swaps means adjusting the Avids 3 clicks every time.Since I want to use these for cross also,I want them to be indentical.
    I measured the thickness with my digital micrometer.Hayes= 1.753mm. Avid 1.837mm.
    I 'll also have to shim all 3 wheelsets to the same position,but that should not be a problem.
    Dan Cas
    no signature
  1. Which spokes for disc wheel build?
    By gabe0807 in forum Wheels and Tires
    Last Post: 08-26-2004, 01:49 PM
  2. Deore disc brake with CODA discs?
    By nusbus in forum General Discussion
    Last Post: 07-09-2004, 06:42 AM
  3. deore discs?
    By xisaacx in forum Brake Time
    Last Post: 07-06-2004, 03:44 PM
  4. Ahoy! V-brake holdouts!
    By Padre in forum Singlespeed
    Last Post: 03-23-2004, 10:06 AM
  5. Tune Disc Hubs & Formula Disc Brakes??
    By Wirth in forum Weight Weenies
    Last Post: 03-05-2004, 05:20 PM
